Programming Art => Eye Candies => Topic started by: Patrice Terrier on May 14, 2021, 09:38:50 am
Title: PhotoComposer
Post by: Patrice Terrier on May 14, 2021, 09:38:50 am
Is a GDImage 32-bit application written in PowerBASIC.
Est une application GDImage 32-bit écrite en PowerBASIC (dispo aussi en WinDev WD17+).
(http://www.objreader.com/download/images/PhotoComposer.png)
The initial purpose of this program is to convert any picture or photography to a postcard, that can be printed or sent as e-mail attachment through the internet.
Le but initial de PhotoComposer est de transformer n'importe quel photo en carte postale, pour l'imprimer ou l'envoyer par internet en pièce jointe
Main features
• Dedicated frame library to change the border style.
• Dedicated icon library to customize the presentation.
• Mix image and text altogether as multiple overlaping layers.
• Change the overlaping order from bottom to top and top to bottom.
• Select the variable opacity for each of the layer.
• Rotate image and text at any angle within the full 360° range.
• Control all parameters of the TrueType text font being used.
• Pan and zoom either the graphics or the annotations.
• High quality display to suppress the "stair case" effect while zooming.
• Use clone to duplicate either image or text with all properties.
• Drag & drop between Windows Explorer and the PhotoComposer form.
• Supported graphic format: bmp, gif, jpg, jpeg, png, tif, tiff.
• Use Outlook Express or Windows mail, to send your work as an attachment.
• PhotoComposer is powered by GDImage.
Caractéristiques principales
• Bibliothèque de bordures pour encadrer les photos.
• Bibliothèque d'icônes pour personnaliser la composition.
• Combinaison d'images et de textes sous forme de calques superposés.
• Changement de l'ordre de superposition vers le haut ou le bas.
• Réglage individuel de la transparence.
• Images et textes peuvent pivoter librement sur 360°.
• Les textes sont paramétrables et utilisent des fontes True Type.
• Un zoom réglable permet d'ajuster la taille de chaque objet.
• L'affichage haute qualité supprime l'effet "escalier" lors des redimensionnements.
• Le clonage permet de dupliquer chaque image ou texte avec ses propriétés.
• Support du "tiré déplacé" entre l'Explorateur et la fenêtre de PhotoComposer.
• Formats graphiques supportés : bmp, gif, jpg, jpeg, png, tif, tiff.
• Compatible Outlook Express et Windows Mail pour l'envoie en pièce jointe.
• PhotoComposer utilise le moteur graphique GDImage.
(http://www.objreader.com/download/images/pc_help.png)
User guide:
To display the help file, press the blue icon asside the language flag.
Guide utilisateur :
Pour consulter l'aide, presser sur l'icone bleu du personnage qui se trouve à côté du drapeau qui permet de basculer entre français et anglais.
Source code 32-bit / Code source 32-bit :
Available on request in either PowerBASIC or WinDev (WD17+), request a valid GDImage license.
Disponible à la demande soit en PowerBASIC soit en WinDev (WD17+), nécessite une licence GDImage valide.
Donation:
If you like this project
(https://www.paypalobjects.com/en_US/FR/i/btn/btn_donateCC_LG.gif)
Click here to make a donation (https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=CYT962VNJATVU&source=url)
Or you can also use: paypal.me (http://paypal.me/patriceTERRIER)
