Tips & Tricks => Tips & Tricks => Topic started by: Frank Brübach on November 12, 2024, 02:26:49 pm
Hello Patrice.. perhaps you can Help?
I want to include an openGl Window into a SDK winapi frame. Whats the correct way? My attempt so far.. regards frank
' test openGL sdk window + window frame included with a control
' how to insert an openGL window frame into a sdk window?
#COMPILER PBWIN 10
#COMPILE EXE
#DIM ALL
#INCLUDE ONCE "Win32API.inc"
%IDC_STATIC=1001
%IDC_BUTTON=1002
%BS_PUSHBUTTON = &H0&
FUNCTION WINMAIN (BYVAL hInstance AS DWORD, _
BYVAL hPrevInstance AS DWORD, _
BYVAL lpCmdLine AS ASCIIZ PTR, _
BYVAL iCmdShow AS LONG) AS LONG
LOCAL Msg AS tagMsg
LOCAL wce AS WndClassEx
LOCAL szAppName AS ASCIIZ * 80
LOCAL szAppName2 AS ASCIIZ * 80
LOCAL hWnd AS DWORD
LOCAL hWndOpgl AS DWORD
szAppName = "HelloWin"
wce.cbSize = SIZEOF(wce)
wce.STYLE = %CS_HREDRAW OR %CS_VREDRAW
wce.lpfnWndProc = CODEPTR(WndProc)
wce.cbClsExtra = 0
wce.cbWndExtra = 0
wce.hInstance = hInstance
wce.hIcon = LoadIcon(hInstance, "HELLOWIN")
wce.hCursor = LoadCursor(%NULL, BYVAL %IDC_ARROW)
wce.hbrBackground = %NULL ' No class background, we do it outselves
wce.lpszMenuName = %NULL
wce.lpszClassName = VARPTR(szAppName)
wce.hIconSm = LoadIcon(hInstance, BYVAL %IDI_APPLICATION)
RegisterClassEx wce
szAppName2 = "HelloOpenGL"
wce.cbClsExtra = 0
wce.cbWndExtra = 0
wce.lpszClassName = VARPTR(szAppName2)
RegisterClassEx wce
' Create a window using the registered class
hWnd = CreateWindow(szAppName, _
"The Hello Program", _
%WS_OVERLAPPEDWINDOW, _
%CW_USEDEFAULT, _
%CW_USEDEFAULT, _
%CW_USEDEFAULT, _
%CW_USEDEFAULT, _
%NULL, _
%NULL, _
hInstance, _
BYVAL %NULL)
IF hWnd = 0 THEN ' exit on failure
MSGBOX "Unable to create window"
EXIT FUNCTION
END IF
hWndOpgl = CreateWindow(szAppName2, _
"OpenGL window", _
%CW_USEDEFAULT, _
%CW_USEDEFAULT, _
%CW_USEDEFAULT, _
%CW_USEDEFAULT, _
%NULL, _
%NULL, _
hInstance, _
BYVAL %NULL)
IF hWndOpgl = 0 THEN ' exit on failure
MSGBOX "Unable to create openGLwindow"
EXIT FUNCTION
END IF
LOCAL hCtl AS DWORD
LOCAL hCtlBtn AS DWORD
LOCAL hFont AS DWORD
hCtl = CreateWindowEx(0, "Static", "openGL", _
%WS_CHILD OR %WS_VISIBLE OR %WS_CLIPSIBLINGS OR %WS_TABSTOP OR _
%SS_NOTIFY OR %SS_LEFT, _ '%SS_RIGHT
18, 40, 440, 324, _
hwnd, %IDC_STATIC, GetModuleHandle(""), BYVAL %NULL)
IF hFont THEN SendMessage hCtl, %WM_SETFONT, hFont, 0
hCtlBtn = CreateWindowEx(0, "Button", "push-me", _
%WS_CHILD OR %WS_VISIBLE OR %BS_PUSHBUTTON OR _
%WS_CLIPSIBLINGS OR %WS_TABSTOP, _
650, 440, 80, 24, _
hwnd, %IDC_BUTTON, GetModuleHandle(""), BYVAL %NULL)
IF hFont THEN SendMessage hCtlBtn, %WM_SETFONT, hFont, 0
IF hWnd = 0 THEN
MessageBox(0, "Window Creation Failed!", "Error", 0)
EXIT FUNCTION
END IF
' Display the window on the screen
ShowWindow hWnd, iCmdShow
UpdateWindow hWnd
DO WHILE GetMessage(Msg, %NULL, 0, 0)
TranslateMessage Msg
DispatchMessage Msg
LOOP
FUNCTION = msg.wParam
END FUNCTION
SUB DrawGradient (BYVAL hDC AS DWORD)
' Custom draw procedure for gradiend fill
LOCAL rectFill AS RECT
LOCAL rectClient AS RECT
LOCAL fStep AS SINGLE
LOCAL hBrush AS DWORD
LOCAL lOnBand AS LONG
GetClientRect WindowFromDC(hDC), rectClient
fStep = rectClient.nbottom / 200
FOR lOnBand = 0 TO 199
SetRect rectFill, 0, lOnBand * fStep, rectClient.nright + 1, (lOnBand + 1) * fStep
hBrush = CreateSolidBrush(RGB(0, 0, 255 - lOnBand))
Fillrect hDC, rectFill, hBrush
DeleteObject hBrush
NEXT
END SUB
FUNCTION WndProc (BYVAL hWnd AS DWORD, BYVAL wMsg AS DWORD, _
BYVAL wParam AS DWORD, BYVAL lParam AS LONG) EXPORT AS LONG
LOCAL hDC AS DWORD
LOCAL hInstance AS DWORD
LOCAL pPaint AS PAINTSTRUCT
LOCAL tRect AS RECT
SELECT CASE wMsg
CASE %WM_CREATE
CASE %WM_COMMAND
SELECT CASE LOWRD(wParam)
CASE %IDOK
IF HIWRD(wParam) = %BN_CLICKED THEN
'Trigger search code..
END IF
CASE %IDC_BUTTON
MSGBOX "pushed"
END IF
END SELECT
CASE %WM_PAINT
hDC = BeginPaint(hWnd, pPaint)
GetClientRect hWnd, tRect
SetBkMode hDC, %TRANSPARENT
SetTextColor hDC, %WHITE
DrawText hDC, "Hello, openGL Windows!", -1, tRect, %DT_SINGLELINE OR %DT_CENTER OR %DT_VCENTER
EndPaint hWnd, pPaint
FUNCTION = 1
EXIT FUNCTION
CASE %WM_ERASEBKGND
hDC = wParam
DrawGradient hDC
FUNCTION = 1
EXIT FUNCTION
CASE %WM_DESTROY
PostQuitMessage 0
EXIT FUNCTION
END SELECT
FUNCTION = DefWindowProc(hWnd, wMsg, wParam, lParam)
END FUNCTION
[/Post]
The easiest way, is to use the GDImage WGL_CreateWindow API that is available in both 32 and 64-bit.
It takes care of all the complex PIXELFORMATDESCRIPTOR details, and moreover GDImage has advanced texture support.
Here is the GDImage code for WGL_CreateWindow
FUNCTION WGL_CreateWindow ALIAS "WGL_CreateWindow" (BYVAL dwExStyle AS DWORD, _
BYVAL dwStyle AS DWORD, _
BYVAL x AS LONG, BYVAL y AS LONG, _
BYVAL nWidth AS LONG, BYVAL nHeight AS LONG, _
BYVAL hWndParent AS DWORD, _
BYVAL CtrlID AS DWORD) EXPORT AS DWORD
LOCAL IsInitialized, wcStyle, glDC, glRC AS LONG
LOCAL hWnd, hTemp AS DWORD
LOCAL wc AS WndClassEx
LOCAL zClass AS ASCIIZ * 16
zClass = "GL_CHARTCTRL"
' Create a temporary window for initializing OpenGL context
hTemp = CreateWindowEx(dwExStyle, $GLImageClassName, "", dwStyle, _
0, 0, 0, 0, hWndParent, CtrlID, zInstance(), BYVAL 0)
IF hTemp THEN
' Get device context and rendering context properties from the temporary window
glDC = ZI_GetProperty(hTemp, %ZI_GLDC)
glRC = ZI_GetProperty(hTemp, %ZI_GLRC)
LOCAL pfd AS PIXELFORMATDESCRIPTOR
' Set up the PIXELFORMATDESCRIPTOR structure
pfd.nSize = SIZEOF(pfd)
pfd.nVersion = 1
pfd.dwFlags = %PFD_DRAW_TO_WINDOW OR %PFD_SUPPORT_OPENGL OR %PFD_DOUBLEBUFFER OR %PFD_SUPPORT_GDI
pfd.iPixelType = 0 ' PFD_TYPE_RGBA
pfd.cColorBits = 32
pfd.cRedBits = 0
pfd.cRedShift = 0
pfd.cGreenBits = 0
pfd.cGreenShift = 0
pfd.cBlueBits = 0
pfd.cBlueShift = 0
pfd.cAlphaBits = 1
pfd.cAlphaShift = 0
pfd.cAccumBits = 0
pfd.cAccumRedBits = 0
pfd.cAccumGreenBits = 0
pfd.cAccumBlueBits = 0
pfd.cAccumAlphaBits = 0
pfd.cDepthBits = 24 ' Depth buffer
pfd.cStencilBits = 0
pfd.cAuxBuffers = 0
pfd.iLayerType = 0 ' %PFD_MAIN_PLANE
pfd.bReserved = 0
pfd.dwLayerMask = 0
pfd.dwVisibleMask = 0
pfd.dwDamageMask = 0
' Initialize multisampling
InitMultisample(glDC, pfd)
IF gn_arbMultisampleFormat THEN
' Set up the window class for the OpenGL control
wcStyle = %CS_HREDRAW OR %CS_VREDRAW OR %CS_DBLCLKS OR %CS_OWNDC
wc.cbSize = SIZEOF(wc)
IsInitialized = GetClassInfoEx(zInstance(), zClass, wc)
IF IsInitialized = 0 THEN
wc.style = wcStyle
wc.lpfnWndProc = CODEPTR(GL_WindowProc)
wc.cbClsExtra = 0
wc.cbWndExtra = %Extend_cbWndExtra * 4
wc.hInstance = zInstance()
wc.hIcon = %NULL
wc.hCursor = LoadCursor(%NULL, BYVAL %IDC_ARROW)
wc.hbrBackground = %NULL ' Don't paint the class window background
wc.lpszMenuName = %NULL
wc.lpszClassName = VARPTR(zClass)
wc.hIconSm = %NULL
IF RegisterClassEx(wc) THEN IsInitialized = %TRUE
END IF
IF IsInitialized THEN
' Create the OpenGL control window
hWnd = CreateWindowEx(dwExStyle, _
zClass, _ ' Make it an OpenGL control
"", _ ' Currently not used
dwStyle, _ ' window style
x, _ ' initial x position
y, _ ' initial y position
nWidth, _ ' Calculate Window Width
nHeight, _ ' Calculate Window Height
hWndParent, _ ' parent window handle
CtrlID, _ ' ControlID
zInstance(), _ ' program instance handle
BYVAL 0) ' creation parameters
IF hWnd THEN
' Get device context and set pixel format
glDC = GetDC(hWnd)
IF SetPixelFormat(glDC, gn_arbMultisampleFormat, pfd) THEN
' Destroy the temporary window and create the OpenGL context
DestroyWindow(hTemp)
glRC = wglCreateContext(glDC)
wglMakeCurrent(glDC, glRC)
ZI_SetProperty(hWnd, %ZI_GLDC, glDC)
ZI_SetProperty(hWnd, %ZI_GLRC, glRC)
ELSE
' Fallback: use the temporary window
DestroyWindow(hWnd)
MoveWindow(hTemp, x, y, nWidth, nHeight, 0)
hWnd = hTemp
END IF
END IF
END IF
ELSE
hWnd = hTemp
END IF
END IF
FUNCTION = hWnd
END FUNCTION
hello patrice thanks for your code example. but I have questions about some equates
%ZI_GLDC, %ZI_GLRC,%Extend_cbWndExtra, and $GLImageClassName
and ZI_GetProperty() function and ZI_SetProperty() function
do you have a running openGL 32-bit example for me for testing with needed equates and functions?
%ZI_GLDC = ?
%ZI_GLRC = ?
%Extend_cbWndExtra = ?
ZI_SetProperty() function ?
ZI_GetProperty() function ?
what is $GLImageClassName = ? ' "WGL_OpenGL" ???
FUNCTION ZI_GetProperty(BYVAL a AS DWORD, BYVAL b AS DWORD) EXPORT AS DWORD
END FUNCTION
FUNCTION ZI_SetProperty(BYVAL a AS DWORD, BYVAL b AS DWORD,BYVAL c AS DWORD) EXPORT AS DWORD
END FUNCTION
FUNCTION InitMultisample(BYVAL a AS DWORD, BYVAL b AS LONG) EXPORT AS DWORD
END FUNCTION
' update
LOCAL GLImageClassName AS WSTRINGZ*180 ' $GLImageClassName
'$GLImageClassName="WGL_OpenGL" ' ???
LOCAL zInstance AS DWORD
LOCAL gn_arbMultisampleFormat AS LONG
hTemp = CreateWindowEx(dwExStyle, "", "", dwStyle, _ '$GLImageClassName ......... ???
0, 0, 0, 0, hWndParent, CtrlID, zInstance, BYVAL 0)
IF hTemp THEN
pfd.nVersion = 1
pfd.cColorBits = 32
pfd.cRedBits = 0
pfd.cRedShift = 0
pfd.cGreenBits = 0
pfd.cGreenShift = 0
pfd.cBlueBits = 0
pfd.cBlueShift = 0
pfd.cAlphaBits = 1
pfd.cAlphaShift = 0
pfd.cAccumBits = 0
pfd.cAuxBuffers = 0
pfd.bReserved = 0
pfd.dwLayerMask = 0
InitMultisample(glDC, VARPTR(pfd)) ' ???
IsInitialized = GetClassInfoEx(zInstance, zClass, wc)
wc.style = wcStyle
wc.cbClsExtra = 0
wc.hIcon = %NULL
wc.hIconSm = %NULL
END IF
zInstance, _ ' program instance handle
IF hWnd THEN
glDC = GetDC(hWnd)
ELSE
DestroyWindow(hWnd)
hWnd = hTemp
END IF
END IF
END IF
ELSE
hWnd = hTemp
END IF
END IF
FUNCTION = hWnd
END FUNCTION
See the 3D Chart project written in PowerBASIC
http://www.objreader.com/index.php?topic=17.msg6291#msg6291
The same project is also avalable in C/C++ 64-bit for comparison purpose.
Bonjour et merci beaucoup zu pour cette example .. thanks , Frank
