Author Topic: Helios(2) revisited  (Read 99557 times)
Helios(2) revisited
« on: June 17, 2018, 04:27:29 pm »
I have reworked all the meshes for compatibility with OR version #2.52, and the latest mtxRotate function.
I hope to have fixed everything.   ::)
Re: Helios(2) revisited
« Reply #1 on: June 17, 2018, 05:48:36 pm »
What do you think was causing improper rotating mesh behavior in the preceding version of the model?
I think the blue jets could be made glowing in the dark. Currently, there isn't a single spot in the entire model that would glow when the scene lighting is dimmed.
Otherwise, the model looks flawless. :)
« Reply #2 on: June 17, 2018, 06:04:24 pm »
There was a material missing, and i was forced to use a Y offset of 5.663 for all static meshes, to have a perfect rotation with the rotating group.
And i changed the loading order of the meshes, all these changes seem to have cured the problem.
Stay tune, i shall post soon another model with rotating meshes for test purpose…
« Reply #3 on: June 17, 2018, 09:01:25 pm »
There was a material missing ...
This shouldn't affect anything because in this case, ObjReader would simply use its default material to depict the mesh.
... i was forced to use a Y offset of 5.663 for all static meshes ...
Yes, you have to ensure your model is perfect if you want to rotate some of its meshes synchronously.
And i changed the loading order of the meshes ...
... which makes me think there are still some parameters somewhere that don't get re-initialized from material to material when reading the MAT file. I'm wondering if the existing "material cache" is compatible with the new functionalities we're adding to our meshes...
« Reply #4 on: June 17, 2018, 09:37:17 pm »
i didn't change anything into the rotating group, but i had to change slightly the Y offset of the other meshes to make sure that they match exactly the center of the Y rotation axis.
The missing material was causing the rotation of the matching mesh, that was indeed a static one that shouldn't rotate.
To check everything, i started from the rotation group alone, then adding one by one all other meshes, to detect what could be the problem, boring job to say the least…  :(
« Last Edit: June 17, 2018, 09:39:09 pm by Patrice Terrier »
« Reply #5 on: June 17, 2018, 11:04:17 pm »
The missing material was causing the rotation of the matching mesh, that was indeed a static one that shouldn't rotate. ... boring job to say the least…  :(
Thanks for walking that extra mile, Patrice! Your description will probably help isolate the bug. :)
