Author Topic: FBX Review  (Read 91868 times)
FBX Review
« on: July 11, 2018, 10:31:23 am »
I have installed the Autodesk FBX Review, but while it can deal with several format it doesn't allow the reading of .max format   ::)
Does there is one free software that allows to read .max file ?
Re: FBX Review
« Reply #1 on: July 11, 2018, 02:13:47 pm »
Unfortunately no, Patrice,
You can only read (or even view!) a .MAX/.MA, .C4D, .LWS/.LWO (and some other pro-grade proprietary) file if you have an original full install of 3ds Max/Maya, Cinema 4D, and LightWave Layout/Modeller, respectively.
The internal format of those binary files is so complex that it takes months if not years to hack/reverse engineer them. But the vendors update and modify their file formats every year so basically that it becomes impractical to hack them at all, only to have to start it over and over again with every passing year. ;)
Re: FBX Review
« Reply #2 on: July 11, 2018, 02:49:27 pm »
OK, here is the Zeppelin.max file that i would like to compare with the one i have done for ObjReader.
See if you can convert it to .fbx or .c4d or .obj or .dae.
I am especially interrested to see how they render the body lighting/reflection compared to what we do.
Thanks !
Re: FBX Review
« Reply #3 on: July 11, 2018, 06:07:03 pm »
Hey Patrice,
Catch the converted files. Read the included Readme. 8)
The zip contains 3ds Max renders for your reference. :)
Re: FBX Review
« Reply #4 on: July 11, 2018, 07:05:43 pm »
OK, thank you very much.
Same errors in the .max version, and missing mesh parts than in the obj/fbx version from turbosquid.
And the resulting material quality doesn't come close to what they show here
https://www.turbosquid.com/FullPreview/Index.cfm/ID/732984
I thought the max one would produce better result than the obj/fbx i had, but obviously not.  :(
Thank you again.
Re: FBX Review
« Reply #5 on: July 11, 2018, 07:25:48 pm »
Absolutely.
1. Many authors would, for obvious reasons, deliberately deteriorate their models before they release them for free.
2. The renders they display following that link have all been made under completely different -- much richer -- scene lighting and with the reflective/refractive materials enriched with respective textures that are missing in the distro.
Re: FBX Review
« Reply #6 on: July 11, 2018, 09:19:12 pm »
Fortunatly we have a 3d art restorator among us.  :)
