Author Topic: Oblivion bubble ship  (Read 385775 times)
Re: Oblivion bubble ship
« Reply #75 on: October 01, 2018, 07:49:41 pm »
Ok, i have released the Static version using the new cockpit, the new shadow effect, and new lighting to match the clouds.png wallpaper, and a few more AO textures.
Let's see the FPS you will get with your new GTX.  ;)
« Reply #76 on: October 01, 2018, 07:51:20 pm »
Actually, you don't need the shadow.png map in the static bubble ship zip any more.
Indeed it is still there, but very subtile  8)
« Reply #77 on: October 01, 2018, 08:03:39 pm »
In fact, my existing GTX 650Ti's static bubble ship FPS is exactly 60. :P
It is the flying version with its drone and pilot that seems to have a problematic FPS rate of 15, presumably due to its 2GB VRAM limit. The card seems to be swapping some of its loaded textures into the conventional RAM. :-\
« Reply #78 on: October 02, 2018, 01:32:12 pm »
The official flying version has been released, tell me the FPS you got with your new GTX 1060.
« Last Edit: October 02, 2018, 01:41:37 pm by Patrice Terrier »
« Reply #79 on: October 02, 2018, 03:05:57 pm »
You won't believe it but it's 60FPS (my current exact monitor rate) even in the full screen mode (can't capture it with the FPS counters on) at approx. 40% GPU load. :D
Top left -- ObjReader's FPS counter, bottom right -- Fraps. 8)
« Reply #80 on: October 02, 2018, 04:16:58 pm »
Congratulation, you must be very happy!
I have attached a screen shot of mine, running the OR process alone...
« Last Edit: October 02, 2018, 05:44:44 pm by Patrice Terrier »
« Reply #81 on: October 02, 2018, 08:00:30 pm »
I've got 92 processes = 1425 threads running concurrently with ObjReader. I run a hellofalot of desktop gadgets (ca. 5% CPU power) and a few semi-transparent sliding dockbars (another 4% CPU power) for my tools and apps. ObjReader proper was consuming only 5.1% CPU the moment I took the topmost screenshot below. Regarding GPU consumption, we're on a par with each other when the animated bubble ship is made to rotate at its default zoom on scene load. :D
And ObjReader proper was consuming around 26% CPU when I took the bottommost full-screen shot with the model zoomed in decently to occupy the entire unobscured viewport. :)
It's like heaven and hell compared to my former GTX 650Ti readings, which in their turn were not so bad at all compared to cheaper office-style video cards. And my GPU's temperature at full screen is now ca. 38oC only at 30% fan speed. (not a sound in the room whatsoever! 8) )
