Author Topic: Animated Backgrounds?  (Read 1000490 times)
Re: Animated Backgrounds?
« Reply #45 on: May 23, 2019, 06:07:53 pm »
Yes, I somehow overlooked that possibility. I rarely use my PCs for recording or playback activities these days. I have more than 300 kg of reel-to-reel, cassette and CD audio recorders and players, vinyl LP turntables, amplifiers, speaker cabinets, mixers and other related stuff for that at my disposal. ;D
« Reply #46 on: May 25, 2019, 07:54:44 am »
Wake up, my friend! :D
It's time to enjoy a night flight to ... Mars! :D
I tweaked the shader to work with one buffer and noise texture. It is heavy, but I limited its FPS to 20 so it won't use more than 50% of my GPU at full screen.
Use your mouse to look around as you fly. :)
« Reply #47 on: May 25, 2019, 10:03:23 am »
Thank you, thank you, thank you!
That one, was first on my list for our starship models.
Bravo mon ami !
« Reply #48 on: May 27, 2019, 01:56:03 pm »
Here are some more shader toys for you to play with. :)
« Reply #49 on: May 27, 2019, 02:27:48 pm »
I don't think that these are suitable with the existing models, however thanks anyway !
Do you have already translated the FBSL code to work in OR ?
(i would like to select those that better fit with the existing 3D collection)
http://glslsandbox.com/e#54329.0  done
http://glslsandbox.com/e#54000.2  done
http://glslsandbox.com/e#54001.2  done
http://glslsandbox.com/e#53999.2  done
http://glslsandbox.com/e#53836.0  done
http://glslsandbox.com/e#53816.2  done
http://glslsandbox.com/e#53666.0  done
http://glslsandbox.com/e#52820.0  done
« Last Edit: May 28, 2019, 01:08:46 am by Michael Lobko-Lobanovsky »
« Reply #50 on: May 27, 2019, 07:50:54 pm »
I'm still in the process of doing it. I'm also cleaning the sources of some deprecated and unused stuff.
I think we're in need of another editor panel for our shaders. The problem is there may be two shaders working concurrently now: a design or fancy mode shader and a PP shader, and yet more than one PP shader will be allowed to run concurrently in the future. Thus, the tool window option has become insufficient because OR doesn't know exactly which shader we're going to fine-tune when pressing the Ctrl button.
So, we need a panel to the right of the splitter that would host a scrollable list of sections with controls for each shader in the system like what we have in discrete popup tool windows now. It could be your homework for the immediate future once you get my mods for merging.
« Reply #51 on: May 27, 2019, 10:32:53 pm »
Re. new shaders:
No problem, my friend, though those sources are definitely not so rich, and the shaders, not so sophisticated.
Catch the first batch below: :)
(BTW what can you say about your GPU usage figures in full screen? Are they comparable to mine?)
« Last Edit: May 27, 2019, 10:36:23 pm by Michael Lobko-Lobanovsky »
« Reply #52 on: May 28, 2019, 01:08:19 am »
... and here's the second batch. :)
Note that in Tori, mouse drag controls light flare position rather than viewing angle. The control is however lame and inaccurate.
« Reply #53 on: May 28, 2019, 10:23:39 am »
Voronoi 32%GPU 60FPS
Sirenian Dawn 49%GPU 21FPS
BlueSpace 35%GPU 60FPS
Tori 43%GPU 60FPS
RedHot 45%GPU 32FPS
PurpleSpace 34%GPU 60FPS
Moebius 20%GPU 60FPS
I am using the task manager for the GPU%, and FRAPS version 3.5.99 build 15618 for FPS.
Note: FBSL is a 32-bit application, we may get different results in 64-bit (hopefully better).
« Reply #54 on: May 28, 2019, 01:25:25 pm »
Thank you for the feedback!
Overall, our readings are pretty close, plus or minus. The GPU load is generated by shaders entirely within the GPU alone by its internal microcode regardless of CPU bitness. So, I don't think it will depend noticeably on whether the parent app is 32 or 64 bits, interpreted or natively compiled. The number of parallel processors in the GPU, video data bus width/throughput, and VRAM technology are more important factors that may differ from chip to chip, especially between different generations.
OTOH the other GPU brands like ATi or Intel may yield a yet much more significant spread due to more fundamental differences in their GPU architecture and instruction sets.
« Reply #55 on: May 28, 2019, 02:27:36 pm »
With nVIDIA the 64-bit OpenGL drivers are faster than 32-bit.
« Last Edit: December 14, 2019, 03:56:44 pm by Patrice Terrier »
« Reply #57 on: December 11, 2019, 06:24:49 pm »
I have already done the Oblivion shader, regretfully without the synthesized sound. Yet the sound can be recorded as a stream.
The shader is nice to watch as a nano-movie but I can hardly imagine any model displayed against such a background. ;)
« Reply #58 on: December 11, 2019, 06:29:22 pm »
Re. Graffiti: we can't play video in a shader. So, the rainy background is feasible while Van Damme isn't.
« Reply #59 on: December 11, 2019, 09:05:16 pm »
Yes, some are just a source of inspiration that i have saved to create new BB plugins.
And a few are good candidates for OR, as the one used with Haldin.
