Author Topic: OR small change  (Read 75461 times)
OR small change
« on: September 09, 2019, 04:36:22 pm »
I did a small change into OR, to restore the current static background while switching back from animation (rather than using always "back02.jpg").
Re: OR small change
« Reply #1 on: September 09, 2019, 07:17:14 pm »
Why wouldn't you send me your mods then? :)
Re: OR small change
« Reply #2 on: September 09, 2019, 08:41:31 pm »
Here they are:
void gl_LoadBackgrounds(IN HWND hList, IN BOOL bReset) { // PAT 09-09-2019, new BOOL bReset parameter to restore the current wallpaper rather than "back02.jpg"
    if (IsWindow(hList)) {
        WIN32_FIND_DATAW fd = { 0 };
        WCHAR zTmp[MAX_PATH] = { 0 };
        LVITEM lvi = { 0 };
        lvi.mask = LVIF_TEXT;
        SendMessage(hList, WM_SETREDRAW, FALSE, 0); // else its scrollbars flicker unskinned like hell
        ListView_DeleteAllItems(hList);
        long nCount = 0;
        Path_Combine(zTmp, EXEresource(), L"*.*");
        HANDLE hFind = FindFirstFile(zTmp, &fd);
        if (hFind != INVALID_HANDLE_VALUE) {
            BOOL bFound = TRUE;
            while (bFound) {
                if (!CheckStyle(fd.dwFileAttributes, FILE_ATTRIBUTE_DIRECTORY)) {
                    CharLower(fd.cFileName);
                    if (ZI_IsFileImage(fd.cFileName)) {
                        lvi.iItem = nCount++;
                        lvi.iSubItem = 0;
                        lvi.pszText = fd.cFileName;
                        ListView_InsertItem(hList, &lvi);
                bFound = FindNextFile(hFind, &fd);
            FindClose(hFind);
        if (bReset) { nCount = 0; } // PAT 09-09-2019 restore the current wallpaper rather than "back02.jpg"
        if (nCount) {
            LVFINDINFO lvfi = { 0 };
            lvfi.flags = LVFI_STRING;
            lvfi.psz = L"back02.jpg";
            long nFound = ListView_FindItem(hList, -1, &lvfi);
            if (nFound < 0) { nFound = 0; }
            ListView_SelectPlus(hList, nFound);
        SendMessage(hList, WM_SETREDRAW, TRUE, 0);
        RedrawWindow(hList, NULL, NULL, // this combination of flags seems to do the trick
            RDW_INVALIDATE | RDW_NOERASE | RDW_NOINTERNALPAINT | RDW_ALLCHILDREN | RDW_UPDATENOW);
    case MENU_ANI_BKGND: // MLL 06-01-2019: ani backgrounds
        gP.bAniBkgnd = !gP.bAniBkgnd;
        if (gP.bAniBkgnd) {
            dwStyle = MF_CHECKED;
            resetCurAniShader();
            parseAniShader(L"voronoi.fs"); // default
            if (!gl_LoadAniBackgrounds(GetDlgItem(gP.hMain, IDC_LISTBOX))) {
                CheckMenuItem(gR.hAniMenu, MENU_ANI_BKGND, MF_UNCHECKED);
                EnableMenuItem(gR.hAniMenu, MENU_ANI_BKGND, MF_GRAYED);
            gP.tCurAniBkgndShader.nShaderID = glsl_LoadShaderFromFile("voronoi.fs");
            rAniStart = GetTickCount64() / 1000.0f;
            StartSync();
            dwStyle = MF_UNCHECKED;
            gl_LoadBackgrounds(GetDlgItem(gP.hMain, IDC_LISTBOX), TRUE); // PAT 09-09-2019 use TRUE to restore the current wallpaper rather than "back02.jpg"
            //if (!(gP.bGiration | gP.bUseFPS | gP.bAnimateLights | gP.bRotation | gP.bIsLerping))
            //    StopSync(SYNC_OFF);
        CheckMenuItem(gR.hAniMenu, MENU_ANI_BKGND, dwStyle);
// Forward declarations
void gl_DrawScene();
void gl_LoadBackgrounds(IN HWND hList, IN BOOL bReset);
void StopSync(IN long SYNC_MODE);
void backToStaticBkgnd() { // MLL 06-10-2019:
    BKSHADER* cs = &gP.tCurAniBkgndShader;
    gP.bAniBkgnd = FALSE;
    if (cs->nShaderID) {
        for (int idx = 0; idx <= 3; idx++) {
            if (cs->samplerMapID[idx]) {
                glActiveTexture(GL_TEXTURE0 + idx);
                glBindTexture(GL_TEXTURE_2D, 0);
                glDisable(GL_TEXTURE_2D);
        glActiveTexture(GL_TEXTURE0);
        glEnable(GL_TEXTURE_2D);
        glEnable(GL_LIGHT0);
    gl_LoadBackgrounds(GetDlgItem(gP.hMain, IDC_LISTBOX), FALSE);
    gP.bRedraw = TRUE;
    gl_DrawScene();
            Mobj_ReportError("No animated backgrounds available.\nBackground animation disabled.");
            gl_LoadBackgrounds(hList, FALSE);
            return FALSE;
            // Create ListView to select texture from.
            dwStyle = WS_CHILD | WS_VISIBLE | WS_BORDER | WS_VSCROLL | LVS_REPORT | LVS_SHOWSELALWAYS | LVS_SINGLESEL | LVS_NOCOLUMNHEADER;
            hCtrl = CreateWindowEx(0, WC_LISTVIEW, $NULL, dwStyle, dpi(ClientW - 127), dpi(229+20), dpi(120), dpi(120),  gP.hMain, (HMENU)IDC_LISTBOX, gP.hInstance, NULL);
            if (hCtrl) {
                SendMessage(hCtrl, LVM_SETEXTENDEDLISTVIEWSTYLE, 0, LVS_EX_FULLROWSELECT | LVS_EX_AUTOSIZECOLUMNS);
                lvc.mask = LVCF_FMT | LVCF_WIDTH | LVCF_TEXT | LVCF_SUBITEM;
                GetClientRect(hCtrl, &rc);
                lvc.cx = rc.right; // Column width
                lvc.fmt = LVCFMT_LEFT;
                lvc.pszText = $NULL;
                ListView_InsertColumn(hCtrl, 0, &lvc);
                gl_LoadBackgrounds(hCtrl, FALSE);
« Last Edit: September 09, 2019, 08:43:24 pm by Patrice Terrier »
