Author Topic: [SDK] 10 - Introducing ZSK file ["Business class" SKIN]  (Read 56208 times)
« on: February 09, 2020, 05:09:34 pm »
THIS IS ANOTHER MAJOR RELEASE
introducing the new ZSK file format that stores custom SKIN parameters
Example: BUSI.ZKS ("Business class" SKIN)
'AUTHOR section -------------------------------------------------------------
"AUTHOR,Business class|Skin design: <Patrice Terrier> E-mail: pterrier@zapsolution.com"
'SIZE & COORDINATES section -------------------------------------------------
"CXSYSBUT,            10"          ' Sys buttons X offset from right side.
"CYSYSBUT,            02"          ' Sys buttons Y offset from top side.
"CXSYSICON,           16"          ' Icon X offset from left side.
"CYSYSICON,           09"          ' Icon Y offset from top side.
"CXCAPTEXT,           40"          ' Caption text X offset from left side.
"CYCAPTEXT,           09"          ' Caption text Y offset from top side.
"CXSYSLED,            53"          ' Led X offset from right side.
"CYSYSLED,            24"          ' Led Y offset from top side.
"BTN_FIX_X,           07"          ' Horizontal non stretched button border
"BTN_FIX_Y,           05"          ' Vertical non stretched button border
'BITMAP section -------------------------------------------------------------
"CENTER,              @PATH@Busi\FORM_Center.jpg"
"TOP_LEFT,            @PATH@Busi\FORM_TopLeft.png"
"TOP_MID,             @PATH@Busi\FORM_TopMid.png"
"TOP_RIGHT,           @PATH@Busi\FORM_TopRight.png"
"SIDE_LEFT,           @PATH@Busi\FORM_SideLeft.png"
"SIDE_RIGHT,          @PATH@Busi\FORM_SideRight.png"
"BOTTOM_LEFT,         @PATH@Busi\FORM_BottomLeft.png"
"BOTTOM_MID,          @PATH@Busi\FORM_BottomMid.png"
"BOTTOM_RIGHT,        @PATH@Busi\FORM_BottomRight.png"
"LED,                 @PATH@Busi\BTN_Led.png"
"PUSHBUT,             @PATH@Busi\BTN_Crystal.png"
"CHECKBUT,            @PATH@Busi\BTN_Check.png"
'COLOR section --------------------------------------------------------------
"ACTIVECAPTION,       255,253,245,178" ' Active caption text color.
"INACTIVECAPTION,     255,131,83,61"   ' Inactive caption text color.
"TEXTCOLOR,           255,110,109,113" ' Default ARGB color.
"BTNTEXTCOLOR,        255,255,255,255" ' Push button ARGB text color.
"POPMENUTEXT,         255,16,16,16"    ' PopMenu and Status text ARGB color.
"POPMENUHILITE,       255,196,196,196" ' PopMenu hilite ARGB color.
"ACTIVEMENUBAR,       255,16,16,16"    ' Active menu bar ARGB text color.
"INACTIVEMENUBAR,     255,133,138,133" ' Inactive menu bar ARGB text color.
"CAPTION_FONT,        Trebuchet MS"    ' Caption font
"CAPTION_FONT_HEIGHT, 20"              ' Caption font size
"PUSHBUT_FONT_SIZE,   14"              ' Push button font size
"ICON_SIZE,           24"              ' Icon size
"TRACK_HICOLOR,       255,237,176,71"  ' Track bar hilight color
"PAINT_BORDER,        1"               ' 0 = %PAINT_TILING_MODE, 1 = %PAINT_STRETCH_MODE
"PAINT_BACKGROUND,    1"               ' 0 = %PAINT_TILING_MODE, 1 = %PAINT_STRETCH_MODE
@PATH@ is a macro that means, use current EXE's folder name as root path to the SKIN subfolder.
Using ZSK file and its corresponding SKIN subfolder, allows you to create custom SKIN without editing the source code of the EXE. And with little extra work it is even possible to change the whole SKIN on the fly!
The "Business class" SKIN is using an original design and a complete graphic color chart that must be used with any new controls to keep good looking.
Here is a screen shot of the result
The zInitSkin is the main function to decode the ZSK file, altogether with the zskin.inc file. It must be called just after the creation of the main window and before the creation of any child controls.
'// Load SKIN components and create SYS buttons
SUB zInitSkin (BYVAL hMain AS LONG, zConfigFile AS ASCIIZ)
    LOCAL rc AS RECT
    LOCAL hBut, imgW, imgH, MinSizeX, StartX, StartY, x, y, Done AS LONG
    LOCAL zTip AS ASCIIZ * 20
    LOCAL zImageFile AS ASCIIZ * %MAX_PATH
    LOCAL sExePath, sSkinPath AS STRING
    LOCAL Item, S1, S2, S3, MiC, nProp, xLed, yLed AS LONG
    LOCAL sParam, sBF AS STRING
    IF IsWindow(hMain) THEN
       CALL GetClientRect(hMain, rc)
       CALL zSplitN(zExeName(), sExePath, "")
       Item = 0
       DO WHILE Done = 0
          sBF = LTRIM$(zBufin(zConfigFile, Done))
          IF Done = 0 THEN
             IF ASC(LTRIM$(sBF)) = 39 THEN sBF = "" ' "'"
             S1 = INSTR(sBF, "`")
             S2 = INSTR(-1, sBF, CHR$(34))
             IF S1 = 0 THEN
                S3 = INSTR(-1, sBF, "'"): IF S3 > S2 THEN S1 = S3
             END IF
             IF S1 THEN sBF = RTRIM$(LEFT$(sBF, S1 - 1))
             S1 = INSTR(sBF, CHR$(34))
             IF S1 AND S1 < S2 THEN
                MiC = ASC(sBF, LEN(sBF))
                sBF = UCASE$(MID$(sBF, S1 + 1, S2 - S1 - 1))
                INCR Item
                ON Item GOSUB AUTHOR,CXSYSBUT,CYSYSBUT,CXSYSICON,CYSYSICON,CXCAPTEXT,CYCAPTEXT,CXSYSLED,CYSYSLED, _
                              BTN_FIX_X,BTN_FIX_Y,CENTER,TOP_LEFT,TOP_MID,TOP_RIGHT,SIDE_LEFT,SIDE_RIGHT,BOTTOM_LEFT,BOTTOM_MID,BOTTOM_RIGHT,LED,PUSHBUT,CHECKBUT, _
                              ACTIVECAPTION,INACTIVECAPTION,TEXTCOLOR,BTNTEXTCOLOR,POPMENUTEXT,POPMENUHILITE,ACTIVEMENUBAR,INACTIVEMENUBAR, _
                              CAPTIONFONT,CAPTIONFONTHEIGHT,PUSHBUTFONTSIZE,ICONSIZE,TRACKHICOLOR,PAINT_BORDER,PAINT_BACKGROUND
             END IF
          END IF
       LOOP
       zImageFile = sSkinPath + "BTN_Close.png"
       hBut = zButImage(hMain, zImageFile, -100, -100, %ID_CLOSE)
       CALL zGetImageSize(zGetButImageProperty(hBut), imgW, imgH): imgW = imgW \ 5
       MinSizeX = MinSizeX + imgW
       x = rc.nRight - imgW - StartX: y = StartY: CALL MoveWindow(hBut, x, y, imgW, imgH, %TRUE)
       CALL zSetAnchorMode(hBut, %ANCHOR_RIGHT)
       IF IsFrench() THEN zTip = "Fermer" ELSE zTip = "Close"
       CALL zCreateToolTip(hBut, zTip)
       zImageFile = sSkinPath + "BTN_Restore.png"
       hBut = zButImage(hMain, zImageFile, -100, -100, %ID_RESTORE)
       CALL ShowWindow(hBut, %SW_HIDE)
       x = x - imgW: CALL MoveWindow(hBut, x, y, imgW, imgH, %FALSE)
       IF IsFrench() THEN zTip = "Niveau infĂ©rieur" ELSE zTip = "Restore"
       zImageFile = sSkinPath + "BTN_Maximize.png"
       hBut = zButImage(hMain, zImageFile, -100, -100, %ID_MAXIMIZE)
       IF IsFrench() THEN zTip = "Agrandir" ELSE zTip = "Maximize"
       zImageFile = sSkinPath + "BTN_Minimize.png"
       hBut = zButImage(hMain, zImageFile, -100, -100, %ID_MINIMIZE)
       x = x - imgW: CALL MoveWindow(hBut, x, y, imgW, imgH, %TRUE)
       IF IsFrench() THEN zTip = "Reduire" ELSE zTip = "Iconize"
'      // Create GDIPLUS image from file
       CALL zDrawBackground()
       CALL zMinTrackSizeX(rc.nRight)  ' MinSizeX
       CALL zMinTrackSizeY(rc.nBottom) ' MAX&(imgH, 22)
    END IF
EXIT SUB
AUTHOR:
CALL zSkinAuthor(PARSE$(sBF, 2))
RETURN
CXSYSBUT:
StartX = VAL(PARSE$(sBF, 2))
RETURN
CYSYSBUT:
StartY = VAL(PARSE$(sBF, 2))
RETURN
CXSYSICON:
CALL zCXSYSICON(VAL(PARSE$(sBF, 2)), 1)
RETURN
CYSYSICON:
CALL zCYSYSICON(VAL(PARSE$(sBF, 2)), 1)
RETURN
CXCAPTEXT:
CALL zCXCAPTEXT(VAL(PARSE$(sBF, 2)), 1)
RETURN
CYCAPTEXT:
CALL zCYCAPTEXT(VAL(PARSE$(sBF, 2)), 1)
RETURN
CXSYSLED:
xLed = rc.nRight - VAL(PARSE$(sBF, 2))
RETURN
CYSYSLED:
yLed = VAL(PARSE$(sBF, 2))
RETURN
BTN_FIX_X:
CALL zBTNFIXX(VAL(PARSE$(sBF, 2)), 1)
RETURN
BTN_FIX_Y:
CALL zBTNFIXY(VAL(PARSE$(sBF, 2)), 1)
RETURN
CENTER:
CALL zSetProperty(hMain, %FORM_Center, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
CALL zSplitN(zSkinPath(sBF, sExePath), sSkinPath, "")
CALL zFOLDER(sSkinPath,1)
RETURN
TOP_LEFT:
CALL zSetProperty(hMain, %FORM_TopLeft, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
TOP_MID:
CALL zSetProperty(hMain, %FORM_TopMid, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
TOP_RIGHT:
CALL zSetProperty(hMain, %FORM_TopRight, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
SIDE_LEFT:
CALL zSetProperty(hMain, %FORM_SideLeft, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
SIDE_RIGHT:
CALL zSetProperty(hMain, %FORM_SideRight, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
BOTTOM_LEFT:
CALL zSetProperty(hMain, %FORM_BottomLeft, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
BOTTOM_MID:
CALL zSetProperty(hMain, %FORM_BottomMid, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
BOTTOM_RIGHT:
CALL zSetProperty(hMain, %FORM_BottomRight, zCreateImageFromFile((zSkinPath(sBF, sExePath))))
RETURN
LED:
hBut = zButImage(hMain, (zSkinPath(sBF, sExePath)), xLed, yLed, %ID_LED)
RETURN
PUSHBUT:
'zCreateImageFromFile((zSkinPath(sBF, sExePath)))
RETURN
CHECKBUT:
RETURN
ACTIVECAPTION:
CALL zACTIVECAPTION(zSkinARGB(sBF), 1)
RETURN
INACTIVECAPTION:
CALL zINACTIVECAPTION(zSkinARGB(sBF), 1)
RETURN
TEXTCOLOR:
CALL zTEXTCOLOR(zSkinARGB(sBF), 1)
RETURN
BTNTEXTCOLOR:
CALL zBTNTEXTCOLOR(zSkinARGB(sBF), 1)
RETURN
POPMENUTEXT:
CALL zPOPMENUTEXT(zSkinARGB(sBF), 1)
RETURN
POPMENUHILITE:
CALL zPOPMENUHILITE(zSkinARGB(sBF), 1)
RETURN
ACTIVEMENUBAR:
CALL zACTIVEMENUBAR(zSkinARGB(sBF), 1)
RETURN
INACTIVEMENUBAR:
CALL zINACTIVEMENUBAR(zSkinARGB(sBF), 1)
RETURN
CAPTIONFONT:
CALL zCAPTIONFONT(PARSE$(sBF, 2), 1)
RETURN
CAPTIONFONTHEIGHT:
CALL zCAPTIONFONTHEIGHT(VAL(PARSE$(sBF, 2)), 1)
RETURN
PUSHBUTFONTSIZE:
CALL zPUSHBUTFONTSIZE(VAL(PARSE$(sBF, 2)), 1)
RETURN
ICONSIZE:
CALL zICONSIZE(VAL(PARSE$(sBF, 2)), 1)
RETURN
TRACKHICOLOR:
CALL zTRACKHICOLOR(zSkinARGB(sBF), 1)
RETURN
PAINT_BORDER:
CALL zPAINT_BORDER(VAL(PARSE$(sBF, 2)), 1)
RETURN
PAINT_BACKGROUND:
CALL zPAINT_BACKGROUND(VAL(PARSE$(sBF, 2)), 1)
RETURN
END SUB
All the SKIN properties (functions) are prefixed with "SK_" like these:
FUNCTION SK_AUTHOR() AS STRING
    FUNCTION = zSkinAuthor("")
END FUNCTION
FUNCTION SK_FOLDER() AS STRING
    FUNCTION = zFOLDER("", 0)
END FUNCTION
FUNCTION SK_ACTIVECAPTION() AS LONG
    FUNCTION = zACTIVECAPTION(0, 0)
END FUNCTION
FUNCTION SK_INACTIVECAPTION() AS LONG
    FUNCTION = zINACTIVECAPTION(0,0)
END FUNCTION
FUNCTION SK_TEXTCOLOR() AS LONG
    FUNCTION = zTEXTCOLOR(0,0)
END FUNCTION
FUNCTION SK_BTNTEXTCOLOR() AS LONG
    FUNCTION = zBTNTEXTCOLOR(0,0)
END FUNCTION
FUNCTION SK_POPMENUTEXT() AS LONG
    FUNCTION = zPOPMENUTEXT(0,0)
END FUNCTION
FUNCTION SK_POPMENUHILITE() AS LONG
    FUNCTION = zPOPMENUHILITE(0,0)
END FUNCTION
FUNCTION SK_ACTIVEMENUBAR() AS LONG
    FUNCTION = zACTIVEMENUBAR(0,0)
END FUNCTION
FUNCTION SK_INACTIVEMENUBAR() AS LONG
    FUNCTION = zINACTIVEMENUBAR(0,0)
END FUNCTION
FUNCTION SK_CAPTIONFONT() AS STRING
    FUNCTION = zCAPTIONFONT("", 0)
END FUNCTION
FUNCTION SK_CAPTIONFONTHEIGHT() AS LONG
    FUNCTION = zCAPTIONFONTHEIGHT(0,0)
END FUNCTION
FUNCTION SK_PUSHBUTFONTSIZE() AS LONG
    FUNCTION = zPUSHBUTFONTSIZE(0,0)
END FUNCTION
FUNCTION SK_ICONSIZE() AS LONG
    FUNCTION = zICONSIZE(0,0)
END FUNCTION
FUNCTION SK_TRACKHICOLOR() AS LONG
    FUNCTION = zTRACKHICOLOR(0,0)
END FUNCTION
FUNCTION SK_PAINT_BORDER() AS LONG
    FUNCTION = zPAINT_BORDER(0,0)
END FUNCTION
FUNCTION SK_PAINT_BACKGROUND() AS LONG
    FUNCTION = zPAINT_BACKGROUND(0,0)
END FUNCTION
And for the fun I have added an exclusive "Halo button".
« Last Edit: February 09, 2020, 05:59:58 pm by Patrice Terrier »
Re: [SDK] 10 - Introducing ZSK file ["Business class" SKIN]
« Reply #1 on: February 09, 2020, 06:18:32 pm »
