Author Topic: AudioCap64.DLL  (Read 65116 times)
AudioCap64.DLL
« on: June 08, 2021, 10:26:05 am »
This 64-bit WD17+ (WinDev) project is intended to perform real time audio capture of anything playing on your PC.
The DLL itself is written in C++.
While it could be used to record from the microphone,
the best quality is achieved when using a multiplex audio card and recording from the "Stereo mix" device.
How to Use AudioCap:
  • Start AudioCap.
  • Start playing a movie (with a sound track) or a local or internet audio file (streaming).
  • Press the [Start capture] button, to see the oscilloscope PCM WIMDATA curve.
  • Check "Capture to Wave" if you want to create the "capture.wav", or check "Monitoring only" if you want to see only the peak level.
In "capture to Wave" mode, a WAVE/PCM 44000Hz stereo file is saved in the selected folder.
Note : The demo version of AudioCap64.dll limits the WAVE record to 30 seconds.
How to get the full version:
You can download the full C++ project from codeproject
or from this link.
And you can also make a donation to get the DLL without nag screen and record limitation.
Donation:
If you like this project
Click here to make a donation
Or you can also use: paypal.me
« Last Edit: June 08, 2021, 01:45:32 pm by Patrice Terrier »
