Author Topic: Splash Screen Plus  (Read 63402 times)
Splash Screen Plus
« on: May 25, 2023, 11:33:07 am »
This GDImage64 project has been converted from WinDev to C++ 64-bit, and there is also a PowerBASIC 32-bit version.
It uses a layered window to render GDImage PNG animation, altogether with multiple sprite effects.
The 64-bit code has been optimized to fit within a very small 16384 bytes executable.
Using specific project properties based on the TClib.lib (Tiny C Lib) to replace the default Visual Studio setup.
To start the demo, click on the "On Off" button, then select either next (>>) or prev (<<) to change of splash screen.
To stop the demo, press the close button (X).
Other links about GDImage PNG animations
http://www.objreader.com/index.php?topic=69.0
http://www.objreader.com/index.php?topic=67.0
About the PowerBASIC version
This is the exact transcription of the C++ 64-bit project.
A good example, showing how the core SDK syntax can ease the conversion from one language to another
The 64-bit C++ version is using Unicode, while the 32-bit is using Ansi.
Both resulting EXE size are rather small, 18 Kb for PowerBASIC 32-bit, and 13 Kb for C++ 64-bit.
« Last Edit: June 07, 2023, 08:53:23 am by Patrice Terrier »
