Author Topic: Tutor_03 (C++ VS2022 GDImage64 tutorial)  (Read 39057 times)
« on: June 06, 2023, 03:18:01 pm »
Third post of a series, translated from the "WinDev tutorial",
About Tutor_03
This tutor introduces the use of clone sprites within a GDImage control.
The same bitmap is used by the {reference} sprite, and its clone(s) without wasting the memory.
Each clone has its own set of properties inherited from the {reference} sprite, and they can also be customized.
They are created in the GDImageCreateSprite() procedure.
All sprites/clones are stored along the z-order, from bottom to top, in their order of appearance.
In the CHM help file, search for: ZD_SetObjectZorder and ZD_GetObjectZorder.
Each sprite/clone can have a different label (friendly name), and specific anchor property .
BACKGROUND:
The GDImage graphic control, and the main window are using the same bitmap wallpaper,
see the GDImageUpdateBackround() procedure and the ZI_CreateSkinBackground(...) API.
The bitmap is also updated while processing the WM_SIZE message, with the ResizeGDImageCtrl() procedure.
ANIMATION:
They are handled from the WM_TIMER message and the Animate() procedure.
TEXT ROTATION:
This sprite is using a private font stored in the \Resource folder.
A private font can only be used by the application, without installing it first in Windows.
Last but not least,
the size of the standalone binary EXE is only 20 Kb.
« Last Edit: August 18, 2023, 10:31:13 pm by Patrice Terrier »
