Author Topic: Tutor_08 (C++ VS2022 GDImage64 tutorial)  (Read 49975 times)
« on: June 27, 2023, 06:13:16 pm »
Eighth post of a series, translated from the "WinDev and PowerBASIC",
About Tutor_08
This tutor introduces the use of multiple overlapping transparent layers, working in DWM composited mode.
The "aero_glass.png" used at the top of the z-order is displayed in "ZS_INACTIVE" mode,
that means it is disabled, however, all WM_ messages are passed to the immediate underlaying sprites.
Even the layer shown at the bottom of the z-order is using variable opacity,
which makes it possible to discern the windows desktop in the background.
The fish animation is using 4 bitmaps, each bitmap being composed of multi frames.
See the DetectMultiframe() function.
Last but not least,
the size of the standalone binary EXE is only 13 Kb.
« Last Edit: August 18, 2023, 10:25:39 pm by Patrice Terrier »
