Author Topic: SDK Window including openGl  (Read 100228 times)
Frank Brübach
« on: November 12, 2024, 02:26:49 pm »
Hello Patrice.. perhaps you can Help?
I want to include an openGl Window into a SDK winapi frame. Whats the correct way? My attempt so far.. regards frank
' test openGL sdk window + window frame included with a control
' how to insert an openGL window frame into a sdk window?
#COMPILER PBWIN 10
#COMPILE EXE
#DIM ALL
#INCLUDE ONCE "Win32API.inc"
%IDC_STATIC=1001
%IDC_BUTTON=1002
%BS_PUSHBUTTON      = &H0&
FUNCTION WINMAIN (BYVAL hInstance     AS DWORD, _
                  BYVAL hPrevInstance AS DWORD, _
                  BYVAL lpCmdLine     AS ASCIIZ PTR, _
                  BYVAL iCmdShow      AS LONG) AS LONG
    LOCAL Msg        AS tagMsg
    LOCAL wce        AS WndClassEx
    LOCAL szAppName  AS ASCIIZ * 80
    LOCAL szAppName2 AS ASCIIZ * 80
    LOCAL hWnd       AS DWORD
    LOCAL hWndOpgl       AS DWORD
    szAppName         = "HelloWin"
    wce.cbSize        = SIZEOF(wce)
    wce.STYLE         = %CS_HREDRAW OR %CS_VREDRAW
    wce.lpfnWndProc   = CODEPTR(WndProc)
    wce.cbClsExtra    = 0
    wce.cbWndExtra    = 0
    wce.hInstance     = hInstance
    wce.hIcon         = LoadIcon(hInstance, "HELLOWIN")
    wce.hCursor       = LoadCursor(%NULL, BYVAL %IDC_ARROW)
    wce.hbrBackground = %NULL ' No class background, we do it outselves
    wce.lpszMenuName  = %NULL
    wce.lpszClassName = VARPTR(szAppName)
    wce.hIconSm       = LoadIcon(hInstance, BYVAL %IDI_APPLICATION)
    RegisterClassEx wce
    szAppName2         = "HelloOpenGL"
    wce.cbClsExtra    = 0
    wce.cbWndExtra    = 0
    wce.lpszClassName = VARPTR(szAppName2)
    RegisterClassEx wce
    ' Create a window using the registered class
    hWnd = CreateWindow(szAppName, _
                        "The Hello Program", _
                        %WS_OVERLAPPEDWINDOW, _
                        %CW_USEDEFAULT, _
                        %CW_USEDEFAULT, _
                        %CW_USEDEFAULT, _
                        %CW_USEDEFAULT, _
                        %NULL, _
                        %NULL, _
                        hInstance, _
                        BYVAL %NULL)
    IF hWnd = 0 THEN  ' exit on failure
        MSGBOX "Unable to create window"
        EXIT FUNCTION
    END IF
    hWndOpgl = CreateWindow(szAppName2, _
                        "OpenGL window", _
                        %CW_USEDEFAULT, _
                        %CW_USEDEFAULT, _
                        %CW_USEDEFAULT, _
                        %CW_USEDEFAULT, _
                        %NULL, _
                        %NULL, _
                        hInstance, _
                        BYVAL %NULL)
    IF hWndOpgl = 0 THEN  ' exit on failure
        MSGBOX "Unable to create openGLwindow"
        EXIT FUNCTION
    END IF
    LOCAL hCtl AS DWORD
    LOCAL hCtlBtn AS DWORD
    LOCAL hFont AS DWORD
    hCtl = CreateWindowEx(0, "Static", "openGL", _
              %WS_CHILD OR %WS_VISIBLE OR %WS_CLIPSIBLINGS OR %WS_TABSTOP OR _
              %SS_NOTIFY OR %SS_LEFT, _ '%SS_RIGHT
               18, 40, 440, 324, _
               hwnd, %IDC_STATIC, GetModuleHandle(""), BYVAL %NULL)
    IF hFont THEN SendMessage hCtl, %WM_SETFONT, hFont, 0
    hCtlBtn = CreateWindowEx(0, "Button", "push-me", _
              %WS_CHILD OR %WS_VISIBLE OR %BS_PUSHBUTTON OR _
              %WS_CLIPSIBLINGS OR %WS_TABSTOP, _
               650, 440, 80, 24, _
               hwnd, %IDC_BUTTON, GetModuleHandle(""), BYVAL %NULL)
    IF hFont THEN SendMessage hCtlBtn, %WM_SETFONT, hFont, 0
    IF hWnd = 0 THEN
      MessageBox(0, "Window Creation Failed!", "Error", 0)
      EXIT FUNCTION
    END IF
    ' Display the window on the screen
    ShowWindow hWnd, iCmdShow
    UpdateWindow hWnd
    DO WHILE GetMessage(Msg, %NULL, 0, 0)
        TranslateMessage Msg
        DispatchMessage Msg
    LOOP
    FUNCTION = msg.wParam
END FUNCTION
SUB DrawGradient (BYVAL hDC AS DWORD)
    ' Custom draw procedure for gradiend fill
    LOCAL rectFill AS RECT
    LOCAL rectClient AS RECT
    LOCAL fStep AS SINGLE
    LOCAL hBrush AS DWORD
    LOCAL lOnBand AS LONG
    GetClientRect WindowFromDC(hDC), rectClient
    fStep = rectClient.nbottom / 200
    FOR lOnBand = 0 TO 199
        SetRect rectFill, 0, lOnBand * fStep, rectClient.nright + 1, (lOnBand + 1) * fStep
        hBrush = CreateSolidBrush(RGB(0, 0, 255 - lOnBand))
        Fillrect hDC, rectFill, hBrush
        DeleteObject hBrush
    NEXT
END SUB
FUNCTION WndProc (BYVAL hWnd AS DWORD, BYVAL wMsg AS DWORD, _
                  BYVAL wParam AS DWORD, BYVAL lParam AS LONG) EXPORT AS LONG
    LOCAL hDC    AS DWORD
    LOCAL hInstance AS DWORD
    LOCAL pPaint AS PAINTSTRUCT
    LOCAL tRect  AS RECT
    SELECT CASE wMsg
    CASE %WM_CREATE
    CASE %WM_COMMAND
      SELECT CASE LOWRD(wParam)
      CASE %IDOK
          IF HIWRD(wParam) = %BN_CLICKED THEN
              'Trigger search code..
          END IF
      CASE %IDC_BUTTON
              MSGBOX "pushed"
          END IF
      END SELECT
    CASE %WM_PAINT
        hDC = BeginPaint(hWnd, pPaint)
        GetClientRect hWnd, tRect
        SetBkMode hDC, %TRANSPARENT
        SetTextColor hDC, %WHITE
        DrawText hDC, "Hello, openGL Windows!", -1, tRect, %DT_SINGLELINE OR %DT_CENTER OR %DT_VCENTER
        EndPaint hWnd, pPaint
        FUNCTION = 1
        EXIT FUNCTION
    CASE %WM_ERASEBKGND
        hDC = wParam
        DrawGradient hDC
        FUNCTION = 1
        EXIT FUNCTION
    CASE %WM_DESTROY
        PostQuitMessage 0
        EXIT FUNCTION
    END SELECT
    FUNCTION = DefWindowProc(hWnd, wMsg, wParam, lParam)
END FUNCTION
[/Post]
Re: SDK Window including openGl
« Reply #1 on: November 13, 2024, 09:06:25 am »
The easiest way, is to use the GDImage WGL_CreateWindow API that is available in both 32 and 64-bit.
It takes care of all the complex PIXELFORMATDESCRIPTOR details, and moreover GDImage has advanced texture support.
Here is the GDImage code for WGL_CreateWindow
FUNCTION WGL_CreateWindow ALIAS "WGL_CreateWindow" (BYVAL dwExStyle AS DWORD, _
                                                    BYVAL dwStyle AS DWORD, _
                                                    BYVAL x AS LONG, BYVAL y AS LONG, _
                                                    BYVAL nWidth AS LONG, BYVAL nHeight AS LONG, _
                                                    BYVAL hWndParent AS DWORD, _
                                                    BYVAL CtrlID AS DWORD) EXPORT AS DWORD
    LOCAL IsInitialized, wcStyle, glDC, glRC AS LONG
    LOCAL hWnd, hTemp AS DWORD
    LOCAL wc     AS WndClassEx
    LOCAL zClass AS ASCIIZ * 16
    zClass = "GL_CHARTCTRL"
    ' Create a temporary window for initializing OpenGL context
    hTemp = CreateWindowEx(dwExStyle, $GLImageClassName, "", dwStyle, _
                           0, 0, 0, 0, hWndParent, CtrlID, zInstance(), BYVAL 0)
    IF hTemp THEN
       ' Get device context and rendering context properties from the temporary window
       glDC = ZI_GetProperty(hTemp, %ZI_GLDC)
       glRC = ZI_GetProperty(hTemp, %ZI_GLRC)
       LOCAL pfd AS PIXELFORMATDESCRIPTOR
       ' Set up the PIXELFORMATDESCRIPTOR structure
       pfd.nSize              = SIZEOF(pfd)
       pfd.nVersion           = 1
       pfd.dwFlags            = %PFD_DRAW_TO_WINDOW OR %PFD_SUPPORT_OPENGL OR %PFD_DOUBLEBUFFER OR %PFD_SUPPORT_GDI
       pfd.iPixelType         = 0 ' PFD_TYPE_RGBA
       pfd.cColorBits         = 32
       pfd.cRedBits           = 0
       pfd.cRedShift          = 0
       pfd.cGreenBits         = 0
       pfd.cGreenShift        = 0
       pfd.cBlueBits          = 0
       pfd.cBlueShift         = 0
       pfd.cAlphaBits         = 1
       pfd.cAlphaShift        = 0
       pfd.cAccumBits         = 0
       pfd.cAccumRedBits      = 0
       pfd.cAccumGreenBits    = 0
       pfd.cAccumBlueBits     = 0
       pfd.cAccumAlphaBits    = 0
       pfd.cDepthBits         = 24 ' Depth buffer
       pfd.cStencilBits       = 0
       pfd.cAuxBuffers        = 0
       pfd.iLayerType         = 0 ' %PFD_MAIN_PLANE
       pfd.bReserved          = 0
       pfd.dwLayerMask        = 0
       pfd.dwVisibleMask      = 0
       pfd.dwDamageMask       = 0
       ' Initialize multisampling
       InitMultisample(glDC, pfd)
       IF gn_arbMultisampleFormat THEN
          ' Set up the window class for the OpenGL control
          wcStyle = %CS_HREDRAW OR %CS_VREDRAW OR %CS_DBLCLKS OR %CS_OWNDC
          wc.cbSize = SIZEOF(wc)
          IsInitialized = GetClassInfoEx(zInstance(), zClass, wc)
          IF IsInitialized = 0 THEN
             wc.style         = wcStyle
             wc.lpfnWndProc   = CODEPTR(GL_WindowProc)
             wc.cbClsExtra    = 0
             wc.cbWndExtra    = %Extend_cbWndExtra * 4
             wc.hInstance     = zInstance()
             wc.hIcon         = %NULL
             wc.hCursor       = LoadCursor(%NULL, BYVAL %IDC_ARROW)
             wc.hbrBackground = %NULL ' Don't paint the class window background
             wc.lpszMenuName  = %NULL
             wc.lpszClassName = VARPTR(zClass)
             wc.hIconSm       = %NULL
             IF RegisterClassEx(wc) THEN IsInitialized = %TRUE
          END IF
          IF IsInitialized THEN
             ' Create the OpenGL control window
             hWnd = CreateWindowEx(dwExStyle, _
                                   zClass, _         ' Make it an OpenGL control
                                   "", _             ' Currently not used
                                   dwStyle, _        ' window style
                                   x, _              ' initial x position
                                   y, _              ' initial y position
                                   nWidth, _         ' Calculate Window Width
                                   nHeight, _        ' Calculate Window Height
                                   hWndParent, _     ' parent window handle
                                   CtrlID, _         ' ControlID
                                   zInstance(), _    ' program instance handle
                                   BYVAL 0)          ' creation parameters
             IF hWnd THEN
                ' Get device context and set pixel format
                glDC = GetDC(hWnd)
                IF SetPixelFormat(glDC, gn_arbMultisampleFormat, pfd) THEN
                   ' Destroy the temporary window and create the OpenGL context
                   DestroyWindow(hTemp)
                   glRC = wglCreateContext(glDC)
                   wglMakeCurrent(glDC, glRC)
                   ZI_SetProperty(hWnd, %ZI_GLDC, glDC)
                   ZI_SetProperty(hWnd, %ZI_GLRC, glRC)
                ELSE
                   ' Fallback: use the temporary window
                   DestroyWindow(hWnd)
                   MoveWindow(hTemp, x, y, nWidth, nHeight, 0)
                   hWnd = hTemp
                END IF
             END IF
          END IF
       ELSE
          hWnd = hTemp
       END IF
    END IF
    FUNCTION = hWnd
END FUNCTION
Frank Brübach
« Reply #2 on: November 13, 2024, 02:03:11 pm »
hello patrice thanks for your code example. but I have questions about some equates
%ZI_GLDC, %ZI_GLRC,%Extend_cbWndExtra, and $GLImageClassName
and ZI_GetProperty() function and ZI_SetProperty() function
do you have a running openGL 32-bit example for me for testing with needed equates and functions?
%ZI_GLDC = ?
%ZI_GLRC = ?
%Extend_cbWndExtra = ?
ZI_SetProperty() function ?
ZI_GetProperty() function ?
what is $GLImageClassName = ? '  "WGL_OpenGL" ???
FUNCTION ZI_GetProperty(BYVAL a AS DWORD, BYVAL b AS DWORD) EXPORT AS DWORD
    END FUNCTION
FUNCTION ZI_SetProperty(BYVAL a AS DWORD, BYVAL b AS DWORD,BYVAL c AS DWORD) EXPORT AS DWORD
END FUNCTION
FUNCTION InitMultisample(BYVAL a AS DWORD, BYVAL b AS LONG) EXPORT AS DWORD
    END FUNCTION
' update
    LOCAL GLImageClassName AS WSTRINGZ*180 ' $GLImageClassName
    '$GLImageClassName="WGL_OpenGL" ' ???
    LOCAL zInstance AS DWORD
    LOCAL gn_arbMultisampleFormat AS LONG
    hTemp = CreateWindowEx(dwExStyle, "", "", dwStyle, _ '$GLImageClassName ......... ???
                           0, 0, 0, 0, hWndParent, CtrlID, zInstance, BYVAL 0)
    IF hTemp THEN
       pfd.nVersion           = 1
       pfd.cColorBits         = 32
       pfd.cRedBits           = 0
       pfd.cRedShift          = 0
       pfd.cGreenBits         = 0
       pfd.cGreenShift        = 0
       pfd.cBlueBits          = 0
       pfd.cBlueShift         = 0
       pfd.cAlphaBits         = 1
       pfd.cAlphaShift        = 0
       pfd.cAccumBits         = 0
       pfd.cAuxBuffers        = 0
       pfd.bReserved          = 0
       pfd.dwLayerMask        = 0
       InitMultisample(glDC, VARPTR(pfd)) ' ???
          IsInitialized = GetClassInfoEx(zInstance, zClass, wc)
             wc.style         = wcStyle
             wc.cbClsExtra    = 0
             wc.hIcon         = %NULL
             wc.hIconSm       = %NULL
          END IF
                                   zInstance, _    ' program instance handle
             IF hWnd THEN
                glDC = GetDC(hWnd)
                ELSE
                   DestroyWindow(hWnd)
                   hWnd = hTemp
                END IF
             END IF
          END IF
       ELSE
          hWnd = hTemp
       END IF
    END IF
    FUNCTION = hWnd
END FUNCTION
« Reply #3 on: November 13, 2024, 10:42:34 pm »
See the 3D Chart project written in PowerBASIC
http://www.objreader.com/index.php?topic=17.msg6291#msg6291
The same project is also avalable in C/C++ 64-bit for comparison purpose.
Frank Brübach
« Reply #4 on: November 14, 2024, 11:32:51 am »
Bonjour et merci beaucoup zu pour cette example .. thanks , Frank
