Author Topic: How to create a BBP_GLSL plugin  (Read 48252 times)
« on: December 30, 2025, 06:22:41 pm »
BassBox GLSL Plugin – Minimal Tutorial (Template Walkthrough)
This post explains how to use the provided bbp_GLSL.cpp + GLSL.h template
to build a simple GLSL-based visual plugin for BassBox64 / MBox64.
The goal is not to introduce “modern OpenGL”, but to show how a GLSL fragment shader
is integrated cleanly into the existing BassBox OpenGL pipeline.
The template uses:
- a legacy full-screen quad (glBegin / glVertex)
- a minimal passthrough vertex shader
- a fragment shader driven by audio and time
- a 32-color LUT system shared between CPU and GPU
1) Plugin lifecycle (BBProc)
The host communicates with the plugin through the exported function:
    ExportC long BBProc(BBPLUGIN &BBP);
The most important messages are:
BBP_CREATE
Called once to declare plugin identity and rendering mode.
Here you set:
- title
- author
- version
- BBP_OPENGL (mandatory for GLSL plugins)
BBP_INIT
Called once when the plugin is initialized.
This is where you:
- bind the host OpenGL context (wglMakeCurrent)
- reset OpenGL state
- initialize time and audio variables
- create textures (including the LUT)
- compile and link GLSL shaders
- cache uniform and sampler locations
BBP_RENDER
Called every frame.
This is where you:
- update time and audio values
- send uniforms to the shader
- bind textures
- draw a full-screen quad
BBP_SIZE
Called when the plugin window is resized.
You must update glViewport and internal width/height.
BBP_DESTROY
Called when the plugin is unloaded.
You must delete:
- GLSL program
- textures
- any allocated resources
2) Rendering model
This template uses a very simple and reliable rendering model:
- A full-screen quad is drawn in clip space (-1 .. +1)
- The vertex shader simply forwards gl_Vertex to gl_Position
- The fragment shader runs once per pixel
No VBO, no VAO, no FBO, no multipass.
This keeps the focus on the shader logic itself.
3) Core uniforms provided to the shader
The following uniforms are automatically filled by the plugin:
uniform vec3 iResolution;
- x = viewport width in pixels
- y = viewport height in pixels
- z = 1.0 (convention)
uniform float iTime;
- Accumulated animation time
- Already modulated by audio on the CPU side
- Suitable for driving motion directly
uniform float iAudio;
- Smoothed audio level
- Typically in the range 0.0 .. 1.0 (may slightly exceed)
- Stable enough for visual modulation
uniform vec3 iLutColor;
- One color selected from the 32-color LUT
- Chosen on the CPU side according to audio peaks
- Already normalized (0..1)
uniform vec3 iMouse;
- Present for compatibility
- Currently set to (0,0,0) in the template
- Can be wired later via BBP_MOUSE
uniform vec4 iDate;
- Only iDate.w is used in the template
- Contains raw system time in seconds
- Useful if you need a non-audio-modulated time source
4) LUT system (CPU + GPU)
The template defines a 32-color palette:
- On the CPU:
  - gP.color[32]  : packed ARGB
  - gP.fR/G/B[32]: normalized float values
- On the GPU:
  - a 32x1 RGB texture bound to iChannel1
You can:
- use iLutColor for a single selected color
- sample iChannel1 in the shader for custom palette logic
The LUT texture uses:
- GL_NEAREST filtering
- GL_CLAMP_TO_EDGE wrapping
5) Demo fragment shader (what it shows)
The provided demo shader demonstrates:
- coordinate normalization using iResolution
- time-based animation using iTime
- audio-driven modulation using iAudio
- color tinting using iLutColor
- a simple ring/pulse effect
- a subtle vignette
It does NOT require:
- any texture input
- any mouse interaction
- any advanced OpenGL features
Alpha output is set to 1.0, producing an opaque image.
6) Where to modify things
To change the visual effect:
Edit the quoted GLSL string inside:
    static GLuint CompileShaderFromString()
To add textures:
Populate gP.mt[] in BBP_INIT and sample them as iChannel0..3.
To enable transparency:
- Output alpha < 1.0 in gl_FragColor
- Enable blending in BBP_INIT or BBP_RENDER
- Ensure the host compositing mode supports it
To react more strongly to audio:
- Adjust the scaling of audioNow
- Modify smoothing factor
- Use iAudio directly in the shader
7) Why this template matters
This template is intentionally:
- minimal
- stable
- legacy-compatible
- host-friendly
It avoids:
- undefined OpenGL state
- hidden multipass logic
- fragile modern-only constructs
Once this base works reliably, more complex shaders and techniques
can be layered on top with confidence.
End of tutorial
The VS 2022 bbp_GLSL.zip is attached to this post
« Last Edit: December 30, 2025, 07:38:24 pm by Patrice Terrier »
BBP_Cubism.cpp
« Reply #1 on: January 04, 2026, 10:46:22 am »
BBP_Cubism
Converted from https://www.shadertoy.com/view/ftGfDK
Original created by mrange on 2022-10-08
Audio + color LUT + BBP_plugin integration by Patrice Terrier
Paste this in the BBProc section
    case BBP_CREATE:
        // Host asks: "who are you and what do you render to?"
        strcpy(BBP.title,"Cubism experiment");
        strcpy(BBP.author, "Mrange (Shadertoy)");
        BBP.version  = MAKEWORD(1,0);
        // Critical: This plugin renders using OpenGL into the host-provided GL context.
        BBP.renderto = BBP_OPENGL;
        // Default background ARGB used by host (informational/fallback).
        BBP.backargb = bbpARGB(255,0,0,0);
Paste this in the GLSL.h section
static GLuint CompileShaderFromString() {
    const char* CharBuffer =
    "#version 330 core\n"
    "\n"
    "uniform vec3  iResolution;\n"
    "uniform float iTime;\n"
    "uniform float iAudio;\n"
    "uniform vec3  iLutColor;   // RGB directly from host (lutR,lutG,lutB)\n"
    "\n"
    "out vec4 FragColor;\n"
    "\n"
    "#define TIME        iTime\n"
    "#define RESOLUTION  iResolution\n"
    "#define PI          3.141592654\n"
    "#define TAU         (2.0*PI)\n"
    "#define ROT(a)      mat2(cos(a), sin(a), -sin(a), cos(a))\n"
    "\n"
    "#define TOLERANCE       0.0005\n"
    "#define MAX_RAY_LENGTH  20.0\n"
    "#define MAX_RAY_MARCHES 80\n"
    "#define MAX_SHD_MARCHES 20\n"
    "#define NORM_OFF        0.005\n"
    "\n"
    "const mat2 rot0 = ROT(0.0);\n"
    "mat2 g_rot0 = rot0;\n"
    "\n"
    "const vec4 hsv2rgb_K = vec4(1.0, 2.0 / 3.0, 1.0 / 3.0, 3.0);\n"
    "#define HSV2RGB(c)  (c.z * mix(hsv2rgb_K.xxx, clamp(abs(fract(c.xxx + hsv2rgb_K.xyz) * 6.0 - hsv2rgb_K.www) - hsv2rgb_K.xxx, 0.0, 1.0), c.y))\n"
    "\n"
    "const float hoff = 0.0;\n"
    "\n"
    "// Keep sky exactly as original\n"
    "const vec3 skyCol     = HSV2RGB(vec3(hoff+0.57, 0.90, 0.25));\n"
    "const vec3 skylineCol = HSV2RGB(vec3(hoff+0.02, 0.95, 0.5));\n"
    "const vec3 sunCol     = HSV2RGB(vec3(hoff+0.07, 0.95, 0.5));\n"
    "\n"
    "const vec3 sunDir1    = normalize(vec3(0., 0.05, -1.0));\n"
    "\n"
    "const vec3 lightPos1  = vec3(10.0, 10.0, 10.0);\n"
    "const vec3 lightPos2  = vec3(-10.0, 10.0, -10.0);\n"
    "\n"
    "vec3 sRGB(vec3 t) {\n"
    "  return mix(1.055*pow(t, vec3(1./2.4)) - 0.055, 12.92*t, step(t, vec3(0.0031308)));\n"
    "}\n"
    "\n"
    "vec3 aces_approx(vec3 v) {\n"
    "  v = max(v, 0.0);\n"
    "  v *= 0.6;\n"
    "  float a = 2.51;\n"
    "  float b = 0.03;\n"
    "  float c = 2.43;\n"
    "  float d = 0.59;\n"
    "  float e = 0.14;\n"
    "  return clamp((v*(a*v+b))/(v*(c*v+d)+e), 0.0, 1.0);\n"
    "}\n"
    "\n"
    "float tanh_approx(float x) {\n"
    "  float x2 = x*x;\n"
    "  return clamp(x*(27.0 + x2)/(27.0+9.0*x2), -1.0, 1.0);\n"
    "}\n"
    "\n"
    "float rayPlane(vec3 ro, vec3 rd, vec4 p) {\n"
    "  return -(dot(ro,p.xyz)+p.w)/dot(rd,p.xyz);\n"
    "}\n"
    "\n"
    "float box(vec2 p, vec2 b) {\n"
    "  vec2 d = abs(p)-b;\n"
    "  return length(max(d,0.0)) + min(max(d.x,d.y),0.0);\n"
    "}\n"
    "\n"
    "float box(vec3 p, vec3 b) {\n"
    "  vec3 q = abs(p) - b;\n"
    "  return length(max(q,0.0)) + min(max(q.x,max(q.y,q.z)),0.0);\n"
    "}\n"
    "\n"
    "float ref(inout vec3 p, vec3 r) {\n"
    "  float d = dot(p, r);\n"
    "  p -= r*min(0.0, d)*2.0;\n"
    "  return d < 0.0 ? 0.0 : 1.0;\n"
    "}\n"
    "\n"
    "vec3 render0(vec3 ro, vec3 rd) {\n"
    "  vec3 col = vec3(0.0);\n"
    "  float sf = 1.0001-max(dot(sunDir1, rd), 0.0);\n"
    "  col += skyCol*pow((1.0-abs(rd.y)), 8.0);\n"
    "  col += clamp(vec3(mix(0.0025, 0.125, tanh_approx(.005/sf))/abs(rd.y))*skylineCol, 0.0, 10.0);\n"
    "  sf *= sf;\n"
    "  col += sunCol*0.00005/sf;\n"
    "\n"
    "  float tp1  = rayPlane(ro, rd, vec4(vec3(0.0, -1.0, 0.0), 6.0));\n"
    "\n"
    "  if (tp1 > 0.0) {\n"
    "    vec3 pos  = ro + tp1*rd;\n"
    "    vec2 pp = pos.xz;\n"
    "    float db = box(pp, vec2(5.0, 9.0))-3.0;\n"
    "    col += vec3(4.0)*skyCol*rd.y*rd.y*smoothstep(0.25, 0.0, db);\n"
    "    col += vec3(0.8)*skyCol*exp(-0.5*max(db, 0.0));\n"
    "  }\n"
    "\n"
    "  return clamp(col, 0.0, 10.0);\n"
    "}\n"
    "\n"
    "float df(vec3 p) {\n"
    "  p.xz *= g_rot0;\n"
    "  vec3 p0 = p;\n"
    "  vec3 p1 = p;\n"
    "  vec3 p2 = p;\n"
    "\n"
    "  // --- AUDIO BREATHING (SHRINK ON LOUD TO AVOID COLLISIONS) ---\n"
    "  float a = max(iAudio, 0.0);\n"
    "  a = 1.0 - exp(-1.5 * a);\n"
    "  float breathe = 1.0 - 0.10 * a;\n"
    "  breathe = clamp(breathe, 0.75, 1.0);\n"
    "\n"
    "  const float ss = 1.;\n"
    "  p0.y -= -0.2;\n"
    "  p0.z = abs(p0.z);\n"
    "  p0.x = -abs(p0.x);\n"
    "  p0.x -= -0.4*ss;\n"
    "  ref(p0, normalize(vec3(1.0, -0.05, -1.0)));\n"
    "  p0.x -= 1.3*ss;\n"
    "  ref(p0, normalize(vec3(1.0, 0.30, 1.0)));\n"
    "  p0.x -= 1.4*ss;\n"
    "  p0.z -= 0.3*ss;\n"
    "  ref(p0, normalize(vec3(1.0, -1.0, 0.5)));\n"
    "  p0.x -= 1.25*ss;\n"
    "  p0.z -= -0.5*ss;\n"
    "  p0.y -= -0.3*ss;\n"
    "  float d0 = box(p0, vec3(0.5) * breathe)-0.0125;\n"
    "\n"
    "  p1.x -= 0.4;\n"
    "  p1.y -= 0.75;\n"
    "  float d1 = box(p1, vec3(1.25) * breathe)-0.0125;\n"
    "\n"
    "  p2.y += 2.0;\n"
    "  float d2 = p2.y;\n"
    "\n"
    "  float d = d1;\n"
    "  d = min(d, d0);\n"
    "  d = min(d, d2);\n"
    "  return d;\n"
    "}\n"
    "\n"
    "vec3 normal(vec3 pos) {\n"
    "  vec2  eps = vec2(NORM_OFF,0.0);\n"
    "  vec3 nor;\n"
    "  nor.x = df(pos+eps.xyy) - df(pos-eps.xyy);\n"
    "  nor.y = df(pos+eps.yxy) - df(pos-eps.yxy);\n"
    "  nor.z = df(pos+eps.yyx) - df(pos-eps.yyx);\n"
    "  return normalize(nor);\n"
    "}\n"
    "\n"
    "float rayMarch(vec3 ro, vec3 rd, float initt) {\n"
    "  float t = initt;\n"
    "  for (int i = 0; i < MAX_RAY_MARCHES; ++i) {\n"
    "    if (t > MAX_RAY_LENGTH) { t = MAX_RAY_LENGTH; break; }\n"
    "    float d = df(ro + rd*t);\n"
    "    if (d < TOLERANCE) break;\n"
    "    t += d;\n"
    "  }\n"
    "  return t;\n"
    "}\n"
    "\n"
    "float shadow(vec3 lp, vec3 ld, float mint, float maxt) {\n"
    "  const float ds = 1.0-0.4;\n"
    "  float t = mint;\n"
    "  float nd = 1E6;\n"
    "  const float soff = 0.05;\n"
    "  const float smul = 1.5;\n"
    "  for (int i=0; i < MAX_SHD_MARCHES; ++i) {\n"
    "    vec3 p = lp + ld*t;\n"
    "    float d = df(p);\n"
    "    if (d < TOLERANCE || t >= maxt) {\n"
    "      float sd = 1.0-exp(-smul*max(t/maxt-soff, 0.0));\n"
    "      return t >= maxt ? mix(sd, 1.0, smoothstep(0.0, 0.025, nd)) : sd;\n"
    "    }\n"
    "    nd = min(nd, d);\n"
    "    t += ds*d;\n"
    "  }\n"
    "  return sd;\n"
    "}\n"
    "\n"
    "vec3 boxCol(vec3 col, vec3 nsp, vec3 rd, vec3 nnor, vec3 nrcol, float nshd1, float nshd2) {\n"
    "  // --- LUT-driven cube palette (from host RGB) ---\n"
    "  vec3 lut  = clamp(iLutColor, 0.0, 1.0);\n"
    "  vec3 diff1 = lut;\n"
    "  vec3 diff2 = mix(lut, vec3(1.0), 0.25);\n"
    "  vec3 rim   = mix(lut, vec3(1.0), 0.50);\n"
    "\n"
    "  float nfre  = 1.0+dot(rd, nnor);\n"
    "  nfre        *= nfre;\n"
    "\n"
    "  vec3 nld1   = normalize(lightPos1-nsp);\n"
    "  vec3 nld2   = normalize(lightPos2-nsp);\n"
    "\n"
    "  float ndif1 = max(dot(nld1, nnor), 0.0);\n"
    "  ndif1       *= ndif1;\n"
    "\n"
    "  float ndif2 = max(dot(nld2, nnor), 0.0);\n"
    "  ndif2       *= ndif2;\n"
    "\n"
    "  vec3 scol = vec3(0.0);\n"
    "  float rf = smoothstep(1.0, 0.9, nfre);\n"
    "  scol += diff1*ndif1*nshd1;\n"
    "  scol += diff2*ndif2*nshd2;\n"
    "  scol += 0.1*(skyCol+skylineCol);\n"
    "  scol += nrcol*0.75*mix(vec3(0.25), rim, nfre);\n"
    "\n"
    "  col = mix(col, scol, rf*smoothstep(90.0, 20.0, dot(nsp, nsp)));\n"
    "  return col;\n"
    "}\n"
    "\n"
    "vec3 render1(vec3 ro, vec3 rd) {\n"
    "  vec3 skyCol0 = render0(ro, rd);\n"
    "  vec3 col = skyCol0;\n"
    "\n"
    "  float nt = rayMarch(ro, rd, 0.0);\n"
    "  if (nt < MAX_RAY_LENGTH) {\n"
    "    vec3 nsp  = ro + rd*nt;\n"
    "    vec3 nnor = normal(nsp);\n"
    "\n"
    "    vec3 nref  = reflect(rd, nnor);\n"
    "    float nrt  = rayMarch(nsp, nref, 0.2);\n"
    "    vec3 nrcol = render0(nsp, nref);\n"
    "\n"
    "    if (nrt < MAX_RAY_LENGTH) {\n"
    "      vec3 nrsp  = nsp + nref*nrt;\n"
    "      vec3 nrnor = normal(nrsp);\n"
    "      vec3 nrref = reflect(nref, nrnor);\n"
    "      nrcol = boxCol(nrcol, nrsp, nref, nrnor, render0(nrsp, nrref), 1.0, 1.0);\n"
    "    }\n"
    "\n"
    "    float nshd1 = mix(0.0, 1.0, shadow(nsp, normalize(lightPos1 - nsp), 0.1, distance(lightPos1, nsp)));\n"
    "    float nshd2 = mix(0.0, 1.0, shadow(nsp, normalize(lightPos2 - nsp), 0.1, distance(lightPos2, nsp)));\n"
    "\n"
    "    col = boxCol(col, nsp, rd, nnor, nrcol, nshd1, nshd2);\n"
    "  }\n"
    "\n"
    "  return col;\n"
    "}\n"
    "\n"
    "vec3 effect(vec2 p) {\n"
    "  g_rot0 = ROT(-0.2*TIME);\n"
    "\n"
    "  const float fov = tan(TAU/6.0);\n"
    "  const vec3 ro = vec3(0.0, 2.5, 5.0);\n"
    "  const vec3 la = vec3(0.0, 0.0, 0.0);\n"
    "  const vec3 up = vec3(0.1, 1.0, 0.0);\n"
    "\n"
    "  vec3 ww = normalize(la - ro);\n"
    "  vec3 uu = normalize(cross(up, ww));\n"
    "  vec3 vv = cross(ww,uu);\n"
    "  vec3 rd = normalize(-p.x*uu + p.y*vv + fov*ww);\n"
    "\n"
    "  return render1(ro, rd);\n"
    "}\n"
    "\n"
    "void main() {\n"
    "  vec2 fragCoord = gl_FragCoord.xy;\n"
    "  vec2 q = fragCoord/RESOLUTION.xy;\n"
    "  vec2 p = -1. + 2. * q;\n"
    "  p.x *= RESOLUTION.x/RESOLUTION.y;\n"
    "\n"
    "  vec3 col = effect(p);\n"
    "  col = aces_approx(col);\n"
    "  col = sRGB(col);\n"
    "  FragColor = vec4(col, 1.0);\n"
    "}\n";
    GLuint fs = CompileShader(GL_FRAGMENT_SHADER, CharBuffer);
    return fs;
BBP_Glow plugin
« Reply #2 on: January 05, 2026, 10:19:41 am »
BBP_Glow
Converted from https://www.shadertoy.com/view/W3tSR4
Original created by Xor on 2025-08-23
    case BBP_CREATE:
        strcpy(BBP.title,"Volumetric Glow");
        strcpy(BBP.author, "Xor (Shadertoy)");
    "\n"
    "uniform float iAudio;\n" // smoothed audio level (0..~1)
    "\n"
    "\n"
    "#define STEPS 50.0\n"
    "#define FOV   1.0\n"
    "#define BASE_DENSITY 1.5\n"
    "\n"
    "float Audio01() {\n"
    "    a = 1.0 - exp(-1.8 * a);\n"
    "    return clamp(a, 0.0, 1.0);\n"
    "}\n"
    "\n"
    "float volumeField(vec3 p, float density, float wfreq) {\n"
    "    float l = length(p);\n"
    "    vec3 v = cos(abs(p) * wfreq / max(4.0, l) + iTime);\n"
    "    return length(vec4(max(v, v.yzx) - 0.9, l - 4.0)) / density;\n"
    "}\n"
    "\n"
    "vec3 rotate90(vec3 p, vec3 a) {\n"
    "    return a * dot(p, a) + cross(p, a);\n"
    "}\n"
    "\n"
    "// MOIRE FIX: tiny stable per-pixel hash (no noise texture needed)\n"
    "float hash12(vec2 p) {\n"
    "    vec3 p3 = fract(vec3(p.xyx) * 0.1031);\n"
    "    p3 += dot(p3, p3.yzx + 33.33);\n"
    "    return fract((p3.x + p3.y) * p3.z);\n"
    "}\n"
    "\n"
    "void main() {\n"
    "    vec2 center = 2.0 * fragCoord - iResolution.xy;\n"
    "\n"
    "    float a = Audio01();\n"
    "\n"
    "    float breathe = 1.0 - 0.08 * a;\n"
    "\n"
    "    float density = BASE_DENSITY * (1.0 + 1.2 * a);\n"
    "    float wfreq   = 8.0 * mix(1.0, 0.65, a);\n"
    "    float brightness = 0.002 * (1.0 + 0.6 * a);\n"
    "\n"
    "    vec3 axis = normalize(cos(vec3(0.5 * iTime) + vec3(0.0, 2.0, 4.0)));\n"
    "\n"
    "    vec3 dir = rotate90(normalize(vec3(center, FOV * iResolution.y)), axis);\n"
    "\n"
    "    float camZ = -8.0 * mix(1.0, 0.92, a);\n"
    "    vec3 cam = rotate90(vec3(0.0, 0.0, camZ), axis);\n"
    "\n"
    "    // Start point\n"
    "    vec3 pos = cam;\n"
    "\n"
    "    // MOIRE FIX: jitter the start along the ray by a tiny amount (breaks band alignment)\n"
    "    float j = hash12(floor(fragCoord));\n"
    "    pos += dir * (j - 0.5) * 0.10;\n"
    "\n"
    "\n"
    "    for (float i = 0.0; i < STEPS; i += 1.0) {\n"
    "        float vol = volumeField(pos * breathe, density, wfreq);\n"
    "        pos += dir * vol;\n"
    "        float inv = 1.0 / max(vol, 0.02);\n"
    "        col += (cos(pos.z / (1.0 + vol) + iTime + vec3(6.0, 1.0, 2.0)) + 1.2) * inv;\n"
    "    }\n"
    "\n"
    "    col = tanh(brightness * col);\n"
    "}\n";
    return fs;
BBP_DiscoBall plugin
« Reply #3 on: January 08, 2026, 01:54:21 pm »
BBP_DiscoBall
Converted from https://www.shadertoy.com/view/ssycDR
Original created by Shane on 2022-06-08
Audio + accumulator + BBP_plugin integration by Patrice Terrier
This plugin is based on a GLSL shader by Shane and required a true temporal accumulator to reproduce the original visual quality.
The effect relies on stochastic sampling and progressive convergence over time, which means a classic single-pass shader is not sufficient.
A floating-point ping-pong accumulator is used to achieve stable lighting, clean reflections, and low noise in dark areas.
This version goes further by adding audio-driven behavior:
  • Monotonic, audio-sensitive sphere rotation.
  • Automatic accumulation freeze during strong motion to avoid blur.
  • High sample count for stable dark regions.
  • Fully functional in landscape and portrait modes (BassBox64)
The result is a physically coherent, music-reactive disco sphere without geometry tricks or artificial brightness.
The full VS2022 source code is attached to this post.
You must also copy the OrganicUD.jpg texture, inside the bbplugin\texture folder.
« Last Edit: January 17, 2026, 09:54:33 am by Patrice Terrier »
