Author Topic: PNG Optimization  (Read 80734 times)
PNG Optimization
« on: January 10, 2017, 02:47:53 am »
Quote from: Patrice
The gem stone animation is one of the biggest i have, 30000×500 pixels in 32-bit, go figure.
Are you aware of quite a number of SW packages around that could optimize your PNGs efficiently while preserving their alphas where available? And in many cases you might even resort to lossy recompression.
Re: PNG Optimization
« Reply #1 on: January 10, 2017, 08:53:21 am »
Mike--
Thank you very much for the link, i shall try it.
While very interresting to produce smaller disk file, that won't change anything when loaded in memory, because then everything must be turned into 32-bit DIB or standard BITMAP.
« Reply #2 on: January 10, 2017, 05:36:57 pm »
... that won't change anything when loaded in memory ...
That's correct, and the problem seems to have no solution in programmatic user space.
However both DX and OpenGL support a number of image formats (including DDS/DXT) that allow for on-the-fly decompression on the GPU hardware only when the respective texture is needed for a particular render pass.
