Author Topic: Custom Lighting Control  (Read 199741 times)
Re: Custom Lighting Control
« Reply #15 on: February 05, 2018, 08:56:49 pm »
I'll do it immediately as soon as I find a way to marry the panel and IPS to the full screen mode.
WS_EX_TOOLWINDOW alone has fixed the other issues. I don't think it's going to interfere with the Windows 10 DWM, so selective usage is unlikely to be necessary.
Changing the parent from gP.hMain to gP.hGL didn't produce any effect.
« Reply #16 on: February 05, 2018, 09:11:07 pm »
if in ToggleFullScreen() you REM OUT
MoveWindow(gP.hGL, 0, 0, screenWidth, screenHeight, FALSE);
that works,
but then the OpenGL viewport doesn't cover the full display correctly.
Here is to code in am using now in CreateOverlay
// Create a popup GDImage overlay window
HWND CreateOverlay(IN HINSTANCE hInstance) {
    RECT lpr; GetWindowRect(gP.hGL, &lpr);
    DWORD dwStyle = WS_POPUP; // | WS_BORDER; // | WS_VISIBLE;
    DWORD dwExStyle = WS_EX_ACCEPTFILES | WS_EX_TOOLWINDOW;
    HWND hWnd = CreateWindowEx(dwExStyle, GDImageClassName, NULL, dwStyle, lpr.left, lpr.top, OVERLAY_WIDTH, Height(lpr), gP.hMain, 0, hInstance, NULL);
    if (IsWindow(hWnd)) {
        // Add tooltip support to the GDImage control.
        HWND hTip = ZI_CreateToolTip(hWnd, L"");
        if (hTip) {
            SetWindowTheme(hTip, L"", L""); // Important, we must disable the Windows theme to use our own set of colors
            SendMessage(hTip, TTM_SETTIPTEXTCOLOR, skGetSysColor(SKCOLOR_TIPTEXT), 0);
            SendMessage(hTip, TTM_SETTIPBKCOLOR, skGetSysColor(SKCOLOR_TIPBACK), 0);
        // Use gradient background
        ZI_SetProperty(hWnd, ZI_GradientTop, ZD_ARGB(163, 127,127,127));
        ZI_SetProperty(hWnd, ZI_GradientBottom, ZD_ARGB(163, 63,63,63));
        ZI_DwmEnable(hWnd);
        // Setup the messages to monitor
        MonitorMessages(hWnd, (LONG_PTR) GDImageCallBack);
        CreateColorObjects(hWnd);
    return hWnd;
I have done more changes and code cleaning, but that will wait until tomorrow ;)
« Last Edit: February 05, 2018, 09:38:04 pm by Patrice Terrier »
« Reply #17 on: February 06, 2018, 08:38:32 pm »
Here is the best i could do.
That is a problem we have already been fighting with, a couple years ago...
Use WinMerge to see the changes i have done in ToggleFullScreen(), and gl_LoadModel.
I spent two days trying to find the best compromise  ::)
« Reply #18 on: February 07, 2018, 04:17:26 pm »
Here is a new widget, added to the SL panel, put rotate.png into your Reader skin folder.
And apply the attached patch.
« Last Edit: February 07, 2018, 04:24:23 pm by Patrice Terrier »
« Reply #19 on: February 07, 2018, 04:57:33 pm »
Nice and useful in full screen. :)
