Author Topic: HiBot  (Read 94447 times)
HiBot
« on: June 15, 2019, 11:23:36 pm »
Alias "Destructible Robot" by Slava Z. from Sketchfab.
Re: HiBot
« Reply #1 on: June 16, 2019, 08:02:40 am »
The model looks fine enough, thank you! :)
Although decimation could have been a little more accurate, don't you think? Then coupled with a normal map baked off of the hi-res version, the model could probably fit in a hundred thousand polies...
Re: HiBot
« Reply #2 on: June 16, 2019, 09:56:58 am »
I didn't spend much time on this model, i did it while waiting for complex AO computation on a very detailed Galactica that will challenge the work done on Prometheus.
The original fbx and glsl is there, if you want to investigate
https://sketchfab.com/3d-models/destructible-robot-highpoly-0f9c08f0d8d94f3a9938d4d8bf423f46
Re: HiBot
« Reply #3 on: June 16, 2019, 11:14:23 am »
:o
Yeah, I saw it, thanks! It claims to be hi-poly but it's obvious it was already decimated from a much higher resolution model, and decimated carelessly at that... :-\
