Author Topic: Tutor_07 (C++ VS2022 GDImage64 tutorial)  (Read 51161 times)
« on: June 22, 2023, 10:28:20 am »
Seventh post of a series, translated from the "PowerBASIC tutorial",
About Tutor_07
This tutor introduces the use of PRIVATE FONT to create sprite images,
and more specifically True Type Font dingbat pictograms to create them.
Private fonts do not need to be registered in Windows, just put them in your resource folder,
then you ensure that the code using them will always look the same, whatever the computer being used.
There are several dingbats in the resource folder, try to use Gears.ttf to create rotating sprites.
Pictograms are also very handy to be used as markers for the purpose of image annotation.
Last but not least,
the size of the standalone binary EXE is only 14 Kb.
« Last Edit: August 18, 2023, 10:26:33 pm by Patrice Terrier »
