Author Topic: GDIPLUS FLAT API  (Read 74028 times)
GDIPLUS FLAT API
« on: November 14, 2016, 11:02:47 am »
GDIPLUS FLAT API
This one uses Explicit Linking to bypass the extra OOP class encapsulation.
How to use it:
Just include the attached gdipflat.h file into your project.
In the application main section
call the helper function hGDIplus = GdipStart() to init GDIPLUS,
and
call the helper function GdipEnd(hGDIplus) to shut down GDIPLUS.
Example:
int WINAPI wWinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPTSTR lpCmdLine, int nCmdShow) {
    UNREFERENCED_PARAMETER(hPrevInstance);
    UNREFERENCED_PARAMETER(lpCmdLine);
    long nRet = 0;
    LONG_PTR hGDIplus = GdipStart();
    // ALL YOUR CODE GOES THERE
    if (hGDIplus) { GdipEnd(hGDIplus); }
« Last Edit: November 14, 2016, 11:11:47 am by Patrice Terrier »
GdipCreateHICONFromBitmap
« Reply #1 on: December 15, 2016, 09:45:05 am »
That should do it
long GdipCreateHICONFromBitmap (IN LONG_PTR lpImg, OUT HICON &lpIcon) {
    long nRet = -1; // Error
    lpIcon = 0;
    HMODULE hModule = gdiplib();
    if (hModule) {
        long_proc (LONG_PTR, HICON*);
        static zProc hProc;
        if (hProc == 0) { hProc = (zProc) GetProcAddress(hModule, "GdipCreateHICONFromBitmap"); }
        if (hProc) { nRet = hProc(lpImg, &lpIcon); }
Re: GDIPLUS FLAT API
« Reply #2 on: December 16, 2016, 09:40:22 pm »
That should do it.
long GdipCreateBitmapFromResource (IN HINSTANCE hInstance, IN WCHAR* sResourceName, OUT LONG_PTR &lpImg) {
    lpImg = NULL;
    if (hModule) {
        long_proc (HINSTANCE, WCHAR*, LONG_PTR*);
        static zProc hProc;
        if (hProc == 0) { hProc = (zProc) GetProcAddress(hModule, "GdipCreateBitmapFromResource"); }
        if (hProc) { nRet = hProc(hInstance, sResourceName, &lpImg); }
« Last Edit: December 16, 2016, 09:42:52 pm by Patrice Terrier »
James Fuller
« Reply #3 on: December 16, 2016, 11:45:28 pm »
  Thank you again.
James
