Author Topic: Turbine  (Read 128768 times)
Turbine
« on: October 13, 2018, 06:46:46 pm »
Do you see anything to change to that one?
« Last Edit: October 14, 2018, 03:38:24 pm by Patrice Terrier »
Re: Turbine
« Reply #1 on: October 13, 2018, 10:37:15 pm »
 :D
Actually there is one thing: z-buffer fighting near some of the pistons.
Re: Turbine
« Reply #2 on: October 13, 2018, 11:00:37 pm »
You have a lynx eye!  :o
Re: Turbine
« Reply #3 on: October 13, 2018, 11:27:35 pm »
This model was too good to be completely flawless. ;D
Re: Turbine
« Reply #4 on: October 14, 2018, 03:29:29 pm »
The fixed model has been released into the collection.
« Last Edit: October 14, 2018, 03:38:51 pm by Patrice Terrier »
Re: Turbine
« Reply #5 on: October 14, 2018, 05:52:22 pm »
Downloaded, thanks!
Re: Turbine
« Reply #6 on: October 14, 2018, 08:56:56 pm »
I have reworked the model texture set, i would like to use it for the new official release, what do you think?
You know what, i am very pleased of your new top-down lighting  :)
Note: When using "Swap Y,Z axes", we should also swap the rotation axes accordingly...
« Last Edit: October 15, 2018, 05:26:47 pm by Patrice Terrier »
Re: Turbine
« Reply #7 on: October 14, 2018, 10:36:08 pm »
The metals look very realistic. I think this version is better than the older one. :)
Now that we have it, I don't know how we could live without it for so long... :D
;D You bet! ;D
« Last Edit: October 15, 2018, 08:28:57 am by Michael Lobko-Lobanovsky »
Re: Turbine
« Reply #8 on: October 15, 2018, 12:37:30 am »
Catch the fix, Patrice! :)
Re: Turbine
« Reply #9 on: October 15, 2018, 09:47:50 am »
Perfect, thank you!
About the Turbine texture set, mine looks much rougher than the original that is shinny bright.
I don't know wich one is better.
Perhaps something like this:
newmtl turbine_hull
Ka 0.05 0.05 0.05
Kd 0.375 0.375 0.375
Ks 0.375 0.375 0.375
#Ka 0.205 0.205 0.205
#Kd 0.975 0.975 0.975
#Ks 1 1 1
Ns 512
illum 3
BTW, just look at the "turbine_hull" alone to see the AO i have done (that was another great enhancement).
« Last Edit: October 15, 2018, 10:01:50 am by Patrice Terrier »
Re: Turbine
« Reply #10 on: October 15, 2018, 12:34:15 pm »
No Patrice,
This hull looks like white oil painted wood to me. The turbine_hull_color.png hull looked like cast aluminum or duralumin, which it should be in reality. (and AO is great indeed)
Don't hesitate, my friend. Your last choice of textures was very good IMHO. :)
Re: Turbine
« Reply #11 on: October 15, 2018, 05:25:49 pm »
I did some more subtle changes to the materials, and reworked a few meshes.
The collection has been updated…
And for the purist, i have attached the "turbine_hull_AO.psd" to save as "turbine_hull_AO.png" without blades occlusion, because we are using a rotating mesh rather than a static one.  ;)
« Last Edit: October 15, 2018, 09:41:11 pm by Patrice Terrier »
Re: Turbine
« Reply #12 on: October 16, 2018, 08:35:06 am »
Thank you! That's certainly the best version of all!
If you've ever cleaned the AT tower case of a desktop PC, you might have noticed the dust deposits in its coolers. They look exactly like the blade occlusion you're trying to avoid, even though the cooler blades are mostly spinning rather than static. I think the turbine blades may behave in a similar manner.
But the most spectacular sights are the pockhole defects on the hull surface. I think such a turbine must be immediately rejected, withdrawn from service, and sent for remelting. ;D
