Author Topic: More WIP on R3PU  (Read 578995 times)
More WIP on R3PU
« on: July 25, 2018, 10:17:15 pm »
See this SketchFab link to download a low poly .obj version of the original model from Nika ZautashVili
https://skfb.ly/6A7UX
Re: More WIP on R3PU
« Reply #1 on: July 25, 2018, 11:40:01 pm »
Looks very good indeed. But it uses a different, more modern texture+shader technique especially designed to render metal and plastic surfaces with picture perfect quality. Our ubershader won't be able to render this model so well even with all the necessary textures.
But still I'm eager to see how your model is going to look in the end. :)
« Reply #2 on: July 27, 2018, 07:21:15 am »
Looks nice! :)
« Reply #3 on: July 27, 2018, 04:48:43 pm »
I have posted the result of my work into the "Sciece fiction" collection.
Warning, due to the size of the project i had to create two posts, to fit everything  8)
BTW: I think that we can support the comparison with the SketchFab version, even if we are not using the latest texture+shader technique.
« Last Edit: July 27, 2018, 06:11:12 pm by Patrice Terrier »
« Reply #4 on: July 27, 2018, 07:14:42 pm »
Very good!
But as I said, our conventional OpenGL shader can't render the model's "metalness" realistically enough. We need realtime PBR (physically based rendering) shaders and textures to do that.
« Reply #5 on: July 28, 2018, 10:11:58 am »
BTW: I think that we can support the comparison with the SketchFab version ...
Regretfully no, Patrice.
Our current render cannot compare favorably with the SketchFab render the way the materials are currently defined in your .MAT file.
I want to experiment with the model and I think I can come up with much better ObjReader materials.
Note that some of your normal maps have a wrong normal UP direction and thus they exhibit peaks where cave-ins should have been. I don't know how you produced your helmet_4K_bump.png normal map (probably using the original b/w bump map in the nVidia plugin) but I need the same with the normal UP direction reversed. Can you provide me with one so I could experiment a little further?
« Reply #6 on: July 28, 2018, 12:50:19 pm »
Here are those (unchanged) that were provided with the original downloaded from SketchFab.
Please remove the attachment once done.
I am looking forward to see what you come with your material file, and reworked textures. ;)
BTW, i made a few enhancements in my personnal version, merging some meshes from the HP FBX version.
« Last Edit: July 28, 2018, 01:08:02 pm by Michael Lobko-Lobanovsky »
« Reply #7 on: July 28, 2018, 01:12:59 pm »
Thank you Patrice,
Attachments removed as requested.
I already have renders that have considerably better "metalness" than yours. ;)  But let me finish before I submit my WIP to you.
I can prove that SketchFab is cheating; their model is rendered with normal maps different from everything that we can download from their site (.obj or proprietary).  >:(
« Reply #8 on: July 28, 2018, 06:21:56 pm »
I turned the kevlar helmet into a metal one. ;)
« Reply #9 on: July 28, 2018, 06:49:15 pm »
What about these ;D
« Last Edit: July 28, 2018, 07:06:31 pm by Patrice Terrier »
« Reply #10 on: July 28, 2018, 10:51:11 pm »
I did my best. My task was to render it as close to SketchFab as possible. I did much, but most normal maps are not the ones the site uses for its own renders. My biggest failure was to render the suit in "plastic leather", which is impossible with the current normal and specular maps.
The zip contains a new .MAT file. You can WinDiff it with the old one to see the differences. The zip also contains a lot of new textures needed for the new .MAT file. All of them begin with an underscore, so just unzip them all into your existing R3PU folder. They won't interfere with, or overwrite, the existing ones (some of which have naturally become obsolete).
Enjoy! :)
« Reply #11 on: July 29, 2018, 01:45:26 am »
!!! IMPORTANT !!!
Please locate and fix the following materials in your .MAT file (I reworked them):
newmtl cam
Kd 0.25 0.25 0.25
Ks 1.2 1.2 1.2
Ns 512
newmtl cam2
Kd 0.25 0.25 0.25
Ks 1.2 1.2 1.2
Ns 512
newmtl mask_ad_01
Kd 0.45 0.45 0.45
Ks 0.75 0.75 0.75
Ns 512
newmtl mask_big_lock
Kd 0.45 0.45 0.45
Ks 0.75 0.75 0.75
Ns 512
newmtl mask_gen
Kd 0.4 0.4 0.4
Ks 1 1 1
Ns 512
newmtl mc_block
Kd 0.75 0.75 0.75
Ks 1 1 1
Ns 1024
newmtl helmet_logo
Kd 0.75 0.75 0.75
Ks 1 1 1
Ns 256
and add a few more textures from the below zip to your R3PU folder!
« Reply #12 on: July 29, 2018, 02:02:37 am »
The mc_block mesh contains a few tris that either i) have very bad normals that the current normal map makes too prominent to let them stay as they are, or ii) aren't textured at all (miss tex coords completely or have degenerate tex coord triangles).
Can you please try and fix them in your C4D?
« Reply #13 on: July 29, 2018, 07:57:19 am »
Thank you very much for your contribution!
I shall make it the official version, because it is the closest to the original.
I have also reworked a personnal version, with a few more meshes and extra materials, perhaps it will co-exist with the official one ;)
I shall see what i can do for the mc_block.
« Last Edit: July 29, 2018, 09:13:51 am by Patrice Terrier »
« Reply #14 on: July 29, 2018, 09:45:19 am »
About the mc_block, the only way i can do it, is to recreate the mesh from scratch  :(
