Author Topic: Tutor_06 "Carousel" (C++ VS2022 GDImage64 tutorial)  (Read 56668 times)
« on: June 21, 2023, 07:36:26 am »
Sixth post of a series, translated from the "WinDev tutorial",
About Tutor_06
This tutor introduces the use of sprite graphic controls to create a CAROUSEL.
To look good, the application is using WinLIFT to skin the project with two lines of code.
See at the end of the CreateControls() procedure
    // Here is the WinLIFT magic
    if (skInitEngine(L"Tutor.sks", NULL)) {
        if (skSkinWindow(hParent, L"  Dock  |  Undock  |  Minimize  |  Maximize  |  Restore  |  Close  ")) {
            // If hParent has been skinned with success,
            // then update its minimum track size using WinLIFT metrics.
            RECT r; GetWindowRect(hParent, &r);
            MinTrackSizeW(rWidth(r));
            MinTrackSizeH(rHeight(r));
More about this in the WinLIFT section.
This project is using GDImage64 version 7.12, if ever you want to load the sprites from resource rather than disk file.
Last but not least,
the size of the standalone binary EXE is only 19 Kb.
« Last Edit: March 13, 2024, 01:45:40 pm by Patrice Terrier »
Re: Tutor_06 (updated)
« Reply #1 on: March 13, 2024, 01:19:45 pm »
Tutor_06,
has been updated to use the latest GDImage64.dll and WinLIFT64.dll, now with Y slider (like in the 32-bit version).
« Last Edit: March 13, 2024, 01:26:44 pm by Patrice Terrier »
